Order number don't update
Thread begun 12/03/2009 1:49 am by stefano391544 | Last modified 12/03/2009 3:42 pm by Jason Byrnes | 1881 views | 2 replies |
stefano391544
Hi
i have a problem with ecart. I make a order process and all is ok. The order is currecty insert in databse, but if continue with another order the second order overwrite the previous order and mantein the same order number of the previous.
Any help?
Thanks!!!
stefano391544
Probably i must delete the session(id) of the current cart session. But i have other session in page (example for login).
Is possible to delete only the cart session at the end of the order?
The session needs to be derstroyed on the Checkout success page.
If you haveother sessions you wish to save, convert them to application variabels, destroy the session, start a new one, then reset the session variables from the application variables.
For example, if you have a session named UserID you wish to save add the following to the checkout success page after the closing html tag:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
//save the UserID Session Var
$userID $_SESSION['userID'];
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params session_get_cookie_params();
setcookie(session_name(), ''time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
session_destroy();
// Start a New Session
session_start();
// reset the  userID session var
$_SESSION['userID'] = $userID;
