Error in Security Assist Wizard
Thread begun 12/02/2009 3:13 pm by mr hankey | Last modified 12/03/2009 4:00 pm by Eric Mittman | 2484 views | 3 replies |
mr hankey
When I go through the Security Assist wizard and click finish I get the following error:
While executing Onclick in SecurityAssistwizard.htm the following javascript error occured: On line 2410 in C:\......"
Can anyone point me in right direction to resolve?
This is a 64bit machine if that helps.
Many thanks
This may be a problem with the cache file or possibly a corrupt config folder. Here is a link to a page that lists the steps you should take to try and resolve this. You should first try the cache file and if you get the same result then you should try the config folder. Let us know if the issue persists after trying these.
146/
mr hankey
thanks for your help, that solved the issue first time.
many thanks again
That is good to hear, you are very welcome.
