Dual Payment
Thread begun 12/02/2009 12:02 pm by cchesnet148148 | Last modified 12/10/2009 12:58 pm by Eric Mittman | 2777 views | 5 replies |
cchesnet148148
Dual Payment
is there a way for me to offer the use of credit card (linkpoint) and/or use of the customers payment terms they have with us?
You can have multiple checkouts in your site so long as you have service for the gateways you wish to implement. I'm not sure that I understand the situation that you are describing though. If you can please post back and include some more detail about how you would like your checkout to work and we will be glad to help advise or point you in the rite direction.
cchesnet148148
i want majority of the users to use our cc process. but some will have the option to be invoiced for the order and will not use cc.
If you just want to have the local checkout occur only under certain conditions then you will first need to define exactly what those conditions are and how the process should work when the conditions are met and when they are not.
The best way to do this would be to try and describe just how this should work from the perspective of the user that will be going through the process. An example of each scenario would be best. If you can detail how you would like this to work from the perspective of the user we can give you some more specific advice on how to implement this.
cchesnet148148
every user has a default payment method stored in their user profile
95% will be "creditcard" this will have them process the order via the linkpoint api
5% will be "credit terms" the order would be submitted with shipping options but we will bill the charges to there "credit terms" account, we will require a customer PO# for this also.
Alright, this sounds pretty good. So when the user registers you will want to either record the payment choice or assign one for the user.
For the checkout itself you would start with the regular linkpoint checkout. Once you have both of these in place and working the next step would be to get the credit scenario working.
For this you would start out by either querying your user's table to see what type of payment method they will use, or you can store that columns info in a session variable when the user logs in.
You would use this value for the payment method on the checkout page, if the user is paying with the credit account then you would not show the regular billing form but an alternative form to gather the info you need. This alternative form can post to either the same confirm page or an alternate one. If you use the same confirm page you will need to do some customizing of it to get it working with the credit account.
If you use another confirm page it may be easier to setup. When paying with the credit account you would need to query the account info to see what type of credit they have. If they have enough available then you can let them confirm the transaction and subtract the total from the available credit. If there is not enough available credit you can inform them of this and allow them to go back to the cart to update it.
This is a high level overview of how you could have this setup. When it comes to the credit account part please post back with a little more detail about how this part should work and I will advise you on what I can.
