Unknown column 'ja9iibrbaq2f9j5vmkc969frb7' in 'where clause'
Thread begun 12/02/2009 10:55 am by gzirfas374932 | Last modified 12/03/2009 5:12 pm by Jason Byrnes | 2321 views | 3 replies |
gzirfas374932
I have checked my database and my server behaviors and can't figure out where this is coming from. All the columns seem to be defined correctly. I did find someone with a similar problem and changed my fields to text instead of numeric but that didn't help. I made a new cart, double checked everything and the message was still there but with a different long number.
shop.php?artist=sattler&Prod_Id=1
On the confirm.php page, the store order summary behavior is set to store the Session ID into a column in your database. The data type in the store order summary is set to numeric.
Double click the store order summary server behavior on the confirm, page. Find the column that the Session ID is being stored in and make sure the data type is set to text, then click ok.
you may also need to check in the Store Order Details table if the session ID is being stored in a column in the order details table.
gzirfas374932
unknown column in where clause, session id
I did my research and found this fix on an earlier thread. I naturally did this before submitting a post, both columns are set for text. Any more suggestions?
To trouble shoot, find the following line of code:
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
it occur more than once, find all occurrences, and change them to:
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error()."<br /".$WA_Sql);
this will cause the SQL that is generating the error message to be written to the screen to help pinpoint the cause of the problem.
