use of product
Thread begun 12/02/2009 4:24 am by watercolor346374 | Last modified 12/02/2009 6:47 pm by watercolor346374 | 5617 views | 10 replies |
watercolor346374
use of product
I have dynamic dropdowns and attempted to use it for a simple list/menu. I just want to list the counties from my database on my checkout form. I used the instructions and saw that they refer to parent and child, this is not necessary, since my list is just a list of counties and a customer will choose one. Can this product do this and if so, where are the instructions for a simple list/menu.
Thank you
CraigRBeta Tester
do you need it ?
If you are simply creating a list menu which has no dependencies, you don't need to bother with dynamic dropdowns, just use Insert => Form => List/Menu, which can be populated with static or dynamic data.
The dynamic dropdown is useful when you have 2 related lists on the same form, where you wish to limit the options available in the second list, depending upon the selection made in the first
watercolor346374
Hi Craig,
Funny thing is I can do this in plain old php. When It comes to doing it in dreamweavercs3...It does not work for me. All I want to do is take my counties table and populate a list/menu with the ny counties in my webassist checkout form. I have used the form in dreamweaver, then created my recordset, then clicked the dynamic button in prop inspec and it comes up empty. Not sure what I am doing wrong.
Thank you
watercolor346374
Hi Craig,
Thank you
CraigRBeta Tester
if you have your form and your list menu and have added a recordset via the bindings panel, in the properties of the list menu, selecting dynamic will provide a pop-up which, beside Options from recordset, your bound recordset should be listed.
if it isn't, post a url or code snippet and i will take a look
watercolor346374
Here is a compressed page
Thanks Craig,
Here is my page. I was able to do this with sizes and I am missing something with DWCs3.
Thank you
CraigRBeta Tester
you had an error with your option tags.
i can't check the page properly as i dont have the linked files but hopefully this should fix it.
watercolor346374
Hi Craig,
Thank you for your help. The date is still not getting to the form...this is odd.
Thank you
CraigRBeta Tester
date ?
sorry, i was looking at the county list/menu.
does this bit work ?
where is the date that doesn't work?
watercolor346374
You were correct, it is the county list/menu with the recordset rsCounties
