Unable to bind dataset to map
Thread begun 12/01/2009 11:45 pm by tom395097 | Last modified 12/10/2009 12:28 pm by millerb395386 | 3123 views | 4 replies |
tom395097
Hey Guys,
I've been trying all night to get multiple addresses to show up on the google map from a dataset that has been binded into the php file that contains the map, with no success. The addresses will not show up.
I successfully added a static address. But I cannot get the 2nd address from the list to show multiple addresses from a dataset. I clicked the lightning button and added the "Address" value to the Pro Map's "Street Name" and also added the zip code for good measures.
When I do this, the code for the address looks like this:
Street: {ds1::Address}
Zip / Postal Code: {ds1::ZipCode}
the page with the map is:
map.php
the dataset source is:
ds1.html
The PHP page has ds1.html binded properly as a dataset, so I do not know why Google Maps will not show the locations. Please help!!!!!!!!
Thanks,
Thomas
Pro Maps will only be able to retrieve dynamic data from a database using a recordset. It is not compatible with the type of data set you are trying to use.
You should create a MySQL database. In the database add a locations table:
locationID - Primary Key
locationAddress - varchar(45)
locationCity - varchar(45)
locationState - varchar(45)
locationZIP - varchar(45)
locationCountry - varchar(45)
Then add the addresses to the location table.
In Dreamweaver you can create a recordset to retrieve the addresses from the database, then use the recordset in Pro Maps.
millerb395386
The kind of data Map Pro is looking for looks like this
$row_Google_Recordset['business_name']
if you are using PHP.
tom395097
Thanks!
Thanks. It would of made my life 100x easier if it was comparable with datasets. But I finally figured out MySQL and php.
millerb395386
I hear you. I was doing this all by hand until I discovered that Dreamweaver can do it quickly and with less typos :o
