Sample database
Thread begun 12/01/2009 12:14 pm by mr hankey | Last modified 12/02/2009 12:01 pm by Jason Byrnes | 6288 views | 11 replies |
mr hankey
Sample database
Totally new to webassist and was wondering if and where i could download a sample solution/mysql database?
Basically creating a backend system where users can log cases and assign products to them.
Would anyone reccomend the mysql database having foreign keys or can the securtiy assist and data assist php code it generates do all the linking between tables?
Many thanks for your help.
Office Guy-172461
Have a look here:
eCommerce mySQL Database
206/
mr hankey
thanks for the help again Office Guy-172461,is this the only sample database?
I take it modifying this database it pretty much suits most situations?
Thanks again
Office Guy-172461
There are sometimes samples in the download area for your extensions.
You can modify this one anyway you want using tools like phpmyadmin to add and delete columns and/or tables. Just make sure you understand how columns with ID in the name are used to tie the tables together.
This is a good starting point for most projects. You can use the column types as an example of how to define columns you add of similar types.
mr hankey
thanks again,so there is sometimes some in the downloads area? Any other ones just now or just that one?
Many thanks again. the sql file does not create the relationships though by looks of it, ran it and think i need to add them manually.
The relationships are not really needed in the table itself.
See the following thread for further information:
showthread.php?t=2722
mr hankey
Thanks so much Jason, so reading that you basically dont need to setup the relationships in mysql database it all gets done at applicaion level using the extensions in dreamweaver.
When you say force referential integrity would for my application this be needed:
Sales person add a lead, then converts it to a sale and sells multiple products. If he deleted 1 product from the sale or deleted the sale but wanted to close the lead to a non mover just now would this need referential integrity?
Many thanks again.
referential integrity only means that the db will not allow you to delete a parent record (sales person) if there are any children (leads)
If you force referential integrity, you need to be extra diligent in the way you craft the application.
You need to make sure that if you are going to try to delete a sales person, that you first delete any leads that have added by that sales person.
Do you _need_ to force referential integrity? No.
can you benefit from forcing referential integrity? Yes, it will help keep your database clean, and free of orphaned records.
There may be instances though where you want to keep the orphaned records.
As a developer, the choice to force referential integrity needs to be evaluated on a per application basis.
If you do choose to force referential integrity, you need to develop the application to account for it.
mr hankey
Thanks Jason for your help.
In this applications case they would need access to sales peoples cases who have been deleted so would need to keep orphaned records.
So for my app, can this be done without the relationships and done inside php using the extensions.
What I was thinking was, having it when a sales person was deleted the records defaulted to an option "re assign" is it easier to do this in the app?
I do want users having problems updating records becuase of referential integrity so is it best in my situation to have this in the app?
Sorry Jason just getting started out, done alot of reading on mysql and just trying to know work out if i need relationships for this or leave it to the extensions code.
Many thanks
Yeah, in this case, where you want to keep orphaned records, you do not want to create the relationships in the database. instead you want to manage the relationships in the application.
