Power Gallery & Flash Nav Menus
Thread begun 11/30/2009 3:13 pm by andy.schofield283961 | Last modified 12/05/2009 2:53 pm by andy.schofield283961 | 4331 views | 8 replies |
I have added a flash nav menu to my power gallery site and I have two issues which I need help with:
1) When selecting a gallery to edit on the 'choosegallery.php' page. The menu showing the available options 'Add Images', 'Manage Images', etc doesnt display. If I reload the page then the menu appears as should. ??
2) When any popup screen appears, the page background dims and is no longer selectable (as expected) however the FlashNav menu stays available. During long processes a user can select the FlashNav menu and navigate away from the page.
Can anyone help me with either of these issues?
Andy
Justin Nemeth
For #1, does it select the first gallery by default? If you had no galleries defined, then it makes sense for that menu to be hidden until you add at least one gallery.
For #2, you'll have to adjust the z-index properties. Give you flash menu a lower z-index or increase it for the overlay elements in the admin css file.
-justin
One down one to go!
#2 solution works great, so thanks for the quick turnaround on that.
#1 - no this occurs even with galleries defined.
when first loading only 'choose gallery' is shown, if i reload still only first option but this makes sense if no gallery is chosen.
1st step is to choose the gallery, this should then display the other options. but it doesnt. If I reload the page after selecting a gallery all items appear as should be.
Hope this additional info helps identify where the problem might be.
Andy
Justin Nemeth
Have you customized the database or admin login page at all? When you login to the admin, it basically autoselects your first gallery. It seems that is not happening in your case for some reason. In the admin/index.php line 47-54 is what sets the default gallery, so you could do some debugging in that area to see if its returning the correct database record.
var_dump($_SESSION['gallery']); die()
Assuming that looks like it has the correct info, you could try adding session_write_close() just before each header call a few lines below.
-justin
Justin,
Yes I have amended the login to allow multiple logins with SecurityAssist and partial re-write of core pages. And yes it doesnt select a default gallery by default due to this, but functionally that doesnt bother me.
But when i do select a gallery it still doesnt work. I will look at your suggestions, but with this additional info do you think the problem could be elsewhere now?
Justin Nemeth
Its hard to say since there have been modifications. The code works out of the box, so it is something with the updates you've made. If you search in the code for $_SESSION['gallery'] =, that should give you all the places where the gallery info is set. It seems like that session variable is never getting set or is getting overwritten. The admin keys off of that variable to get all of the gallery variables.
You might want to start with the admin/js/choosegallery.js file, my guess is the javascript is not firing correctly. I would use firebug on your page and see if there are any JS errors preventing the events from working.
-justin
Justin,
Its not 100% but it was the session variable as you thought. Need to fully debug but its a lot better shape now.
Unfortunatly I cant say the same for the z-index on the flash menu.
This works if I set the z-index as you previously recommended. However it now falls behind the cssmenu.
I have tried applying a div around the cssmenu and giving it a lower z-index but no better.
Can you help
Justin Nemeth
Its hard to say w/o seeing the code, but it still seems like its a z-index issue to me. Did the code change from when you first made this fix and it was working?
-justin
Justin,
The fix never worked, it only appeared to work since i simply checked that the menu fell behind the overlay of the uploading photo.
As soon as I tried to access the menu it was clear that the fix broke the cssmenu.
If seeing the code will help please let me know what files you need and I'll send, and / or upload to a website for you to see for youself.
Thanks for the help.
