Best way to implement discounts
Thread begun 11/30/2009 1:17 pm by david.aprice316413 | Last modified 2/04/2010 1:02 pm by Eric Mittman | 7066 views | 15 replies |
david.aprice316413
I was wondering if anyone can offer some suggestions on how I can implement a discounts feature to my site.
My client wants to give a % discount when the number of items exceeds x value (i.e. 500) but they want to manage the % themselves through the backend pages I am building for them. They also want the ability to offer free delivery (shipping) if the order value exceeds x amount.
Ok so how do I go about this? By the way this is the first time I am trying discounts. I assume I pass the % in a session variable but I'm not entirely sure how to pass the variable into the calculation. I have read through forums and the help documents but I've not really been able to grasp the best way to implement this.
Dave
the first place a discount will be applied to the cart is on the cart display page.
Create a recordset on this page to look up the discount amount, then use the eCart set session value server behavior to store it in a session. Set the trigger to before page loads. Set the name to "discountAmt", then click the lightning bolt next to value and select the recordset column.
When creating the discount in ecart, set the trigger to:
subtotal For any Column:
if the subtotal of column "Quantity" is ">" a value of "500"
then for the calculation use:
Based on Multiple of Column Subtotal:
subtotal of column "TotalPrice" "Times" "$_SESSION['discountAmt']" "Plus" "0"
for the free shipping, set the shipping rule trigger to:
Subtotal For any column:
If the subtotal of "TotalPrice" is "<" a value of "500"
this way shipping will only be applied if the subtotal is less then $500
david.aprice316413
Thanks for the feeback i'll give it a try
Dave
joe159765
Single Item
Ok so how to we apply this to only a certain item dynamically. Say I have 20 of one item and 6 of another item... As it stands with this calculation a discount is taken off the subtotal of those items because it is over 25 items (my calculation is over 24 items and under 50 items multiple by .10 for a 10% discount)
I want it to only apply to the one item even if another item is in the cart.
Hope this makes sense.
Thanks.
Would you like the same discount rule triggered on the presence and quantity of a particular item, or would you like the discount to only take into consideration the one item and discount only that one item?
If you wanted to just update the trigger for this discount to be based on the quantity of a particular item then you can just adjust the current trigger you have to make it based on the 'Quantity of a specific item in the cart' and specify the id of the item. The rest of the discount should be the same.
If you want to have this only trigger on the item and apply only to that items subtotal you will need to also adjust the calculation portion. You will need to set it to 'Based on an item's column value', then specify the item id and choose the total price column.
joe159765
There are two types of items. And there has to be a certain number of that particular item to get the discount. So let's say there's printed materials and printed books. Well each of these have a bunch of different ones in them. So printed material a has to have x number before discounted while printed material b can not add to that number to get the discount. Hope that makes sense. And prited books gets a different percent off. Thanks.
Do you store the type of the item in a cart column? If so then you can do it the same way I suggested but you will use this column that holds the type of item rather than the item id.
joe159765
understand what you are saying and I will be creating that column the only problem with that and I haven't tried your suggestion out today but it seems like it will discount whatever is a certain type. Meaning if I have 23 of item1 and 5 of item2 and it is set to discount of volume of more than 25 then all of it will be discounted. But it should only discount item1 if it's 25 or more and not item2 even though they are the same type. Thanks for your quick replies today.
I think I see your point here. If you want the discount to apply to any item so long as it has a quantity of 25 or more you should use calculations to do this.
You should have two new calculated columns that will check if the quantity is 25 or greater and the type. You will figure the total discount for that line item based on the TotalPrice column. You will have one calculated column for each item type.
This way in the end you can have a blanket discount rule that will give you a total discount based on the subtotal of the new calculated columns. Here is an example of what one of the calculated columns will look like:
[php]
Type1QuantityDiscount
abs([Quantity] >= 25 && [ItemType] == 1) *( [TotalPrice] * .10)
[php]
This example would check if there is 25 or more of of the item and if it is type 1, of so the column will hold the value of the totalprice for the line item times .10. This will make this column hold 10% of the subtotal for that line item.
joe159765
Awesome. I will give that a try and report back. Thanks a ton for your help.
