check out wizard not working
Thread begun 11/30/2009 11:26 am by watercolor346374 | Last modified 12/02/2009 12:04 pm by Eric Mittman | 2668 views | 6 replies |
watercolor346374
I set up my cart, which is not working on the live test site, but works on local server, then I went through all of the check out wizard steps on the last step for doing the checkout and confirm pages, nothing shows up. I did notice that when I get to the template, it does not show one, but if I click on the preview, I can see what I put in. Then I finish and I get a blank. Also noticed that the button for the ecart object, when clicked does not show my cart and if I double click the cart to add a new one , nothing happens and if I double click edit, nothing happens. I did delete the extension and redownload it, but same stuff keeps happening.
Thank you,
You may be experiencing a corruption of your configuration folder within Dreamweaver. Please follow the instructions in this thread to rename or delete this folder and try this again, if you continue to have problems with this please post back with info about your DW version, and OS.
showpost.php?p=12293&postcount=2
watercolor346374
ecart display mgr
Once I download my extentions, change the config file back?
Office Guy-172461
No you leave it that way, this article explains it a little better:
Solving problems with Dreamweaver
146/
Thanks for posting your link, I should have just done that to begin with.
watercolor346374
still not working
Hi Eric,
I can get into the manager and I go throught all of the steps on the final step it does not show any template chosen. when I click finish nothing happens. Progress has been made, I can get into the program, but I get nothing.
Thank you
I have opened a ticket for you on this so that we can check this out further and exchange some more details in private. To update the ticket please login and visit your support history.
