Big mess, cart on live site, not working, just error messages
Thread begun 11/29/2009 7:28 pm by watercolor346374 | Last modified 11/30/2009 5:57 pm by watercolor346374 | 4634 views | 7 replies |
watercolor346374
Problem : I set up my cart and it works perfectly in my computer's local host MAMP. I made a file on the live site called test2 and uploaded the files. The cart does not show up, just error messges on detail page. Here are the problems with the cart:
1. I go to my product page, click on a product and it brings me to my detail page. I get the message:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/isaacsgr/public_html/meganisaacs/test2/
Then when I click the add to cart, I get the following message. I do not go to the cart. I just get the messages. I have looked at my detail page scripts, the cart php scripts and have no idea why this is happening.
Connections/connMegan.php:13) in /home/isaacsgr/public_html/meganisaacs/test2/WA_eCart/WA_eCart_Definition_PHP.php on line 479
When I click on the shopping bag in the header I get this:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@meganisaacs.isaacsgroup.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.14 (Unix) mod_ssl/2.2.14 OpenSSL/0.9.8l DAV/2 mod_auth_passthrough/2.1 FrontPage/5.0.2.2635 Server at www.meganisaacs.com Port 80
Here is a link to see the messages:
signature.php Once there click on a prod to go to detail page with messages. I did not put all of the images in the test 2 so you will see alt's.
files attatched
Thank you
Office Guy-172461
I would start with this:
Solving the "headers already sent" problem
148/
The error message is reporting the output to occur in the file Connections/connMegan.php at line 13, you only included the connArrow.php file, please send the connMegan.php file.
watercolor346374
connMegan.php file
Thank you Jason.
The error is reporting the problem at line 13 of the Connections/connMegan.php file. the one you sent does not have a line 13, it ends at line 10. It cannot be the same version of the file that is causing the error.
watercolor346374
here is the one I have on test2
Thank you, I appreciate your help.
If you open that file in Dreamweaver, you will see that there are two blank lines after the closing PHP tag at line 10 "?>"
remove those two blank lines to get rid of the error.
watercolor346374
thankyou
Thank you Jason, how simple!!!!!
