Local Delivery how to?
Thread begun 11/29/2009 4:39 pm by tim.wolak331163 | Last modified 1/29/2010 5:43 pm by Eric Mittman | 3932 views | 6 replies |
tim.wolak331163
I need to setup an option in my cart to allow people to select local delivery. This will need to also have a rule that will set a flat rate for different zip codes. Can you suggest how to go about doing this? My first thought is to have a check box for the user to check and then submit.
Thanks,
Tim
Office Guy-172461
Have a look here:
Shipping Pickup Option
168/
You should be able to modify it for what you need.
tim.wolak331163
local Delivery
I have created the check box for customers to select for local delivery and also made the shipping rule as well as the session variable. I do not know how to make the check box change the variable. If I set the variable to 0 the shipping rule works not problem. Can anyone help?
Thanks,
Tim
On the checkout page, create the checkbox, make sure to give it a checked value:
<input name="local" type="checkbox" id="local" value="1">
On the confirm page, create a hidden form field with the same name, Set its value to come from the checkbox on the checkout page:
<input name="local" type="hidden" id="local" value="<?php echo((isset($_POST["local"]))?$_POST["local"]:""?>">
Then add a set session value server behavior. Set the trigger to any form post and set it to get the value from the checkbox:
if (!session_id()) session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
$_SESSION["local"] = "".((isset($_POST["local"]))?$_POST["local"]:"")  ."";
tim.wolak331163
I have added what you have suggested for local delivery however it adds the 5 dollar delivery charge and the usps charge. I'm attaching the cart, checkout and confirm pages.
Thanks,
tim
tim.wolak331163
Would Jason or anyone be able to look at the pages I attached to review my issue?
Thanks,
Tim
If you are getting your new shipping charge and the shipping quote charge you will need to update the trigger for the shipping quote.
In here you will need to add another trigger to the existing condition. This new trigger will check for the session variable local, if the value of this session variable local is not equal to 1.
This will make it so if the one shipping rule is triggered the other will not be.
