update page
Thread begun 11/29/2009 8:22 am by parigiro318823 | Last modified 12/18/2009 10:20 am by parigiro318823 | 4558 views | 8 replies |
parigiro318823
update page
after registration instead going to login page again i would like to go to profilepage
showing all visitor data to update if necessary
make sure the insert record behavior on the registration page does not redirect to another page, then add the Security Assist Authenticate User behavior to the page to perform the login.
make sure the authenticate user behavior is after the insert record behavior.
parigiro318823
update page
i did but does not work รน
i attach the screenshot can have a lookand advise ?
thanks a lot
Please send a copy of the registration page so I can look at the code.
The screen shot you sent was of the checkout and checkout failure pages? I thought this was a problem with registration?
parigiro318823
update page
i'm sorry i send the wrong file
but what i would like is after registration go to profile page showing the last customer entered and after go to checkout page
now after registration in order to have the last customer entered we have to go back to login page
basically what i would like is
registration --> Profile ( show custmer data) ---> checkout
now
registration --->login--->profile ----->checkout
Thanks Roberto
In order to get to the profile page, the user must be logged in.
you need to add the Authenticate User server behavior to the registration page as I stated in my initial response, there is no Authenticate user behavior added to the registration page you have sent.
Follow these steps:
1) double click the insert record server behavior and remove the redirect to the visitors_Profile.php page.
2) Add the security Assist Authenticate user behavior to log the user in. Set it to redirect to the visitors_Profile.php page. make sure the Authenticate User Behavior is after the Insert Record behavior.
parigiro318823
update record
this is what i did but still profile page is empty does not show last entered visitor
In the Authenticate user behavior, you are using the $_SESSION['VisitorEmail'] and $_SESSION['VisitorPassword'] values,
you ned to use the values from the form post instead.
parigiro318823
update record
thanks a lot work perfect now
