How do I format keywords?
Thread began 11/27/2009 2:41 am by CraigR | Last modified 11/30/2009 2:35 pm by CraigR | 1789 views | 2 replies |
CraigRBeta Tester
By default, the returned keyword is formatted within <b></b> tags.
is there a means to format this differently.
Also, I noticed that if the search word is matched exactly, it is returned in the result set, but part of the word does not.
is there a setting to add wildcards to the search parameter, or do i need to do this in php?
thanks
Dani Chankhour
I did a quick test and the Keywords that are returned don't have <b></b> tags.
They are returned in this format:
Test mode | Authorize | Test | 06-18 | eCart
But the Abstract is returned with <b></b> which is how it is returned from the API Call.
In regard to the results set, I'm not sure you can do any thing if part of the word is entered because the results are returned from the API call.
But you might be able to do some checking on the search term and try adding words that always return results.
CraigRBeta Tester
thanks Dani.
As I am doing an 'internal' site search. i think i'll write it myself
