insert record fails if server validation is applied
Thread begun 11/25/2009 6:29 am by dean248377 | Last modified 11/25/2009 11:16 am by Jason Byrnes | 1681 views | 1 replies |
dean248377
my insert record works just fine until I apply server side validation. The validation works it just causes the form to not insert.
heres some of the code, I palced the server validation code right after the required statements and befor the rest of the page code, is that the correct thing to do?
if ("" == "") {
$WAFV_Redirect = "registration_terms.php";
$_SESSION['WAVT_custregistration_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["terms"]))?$_POST["terms"]:"") . "",false,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"custregistration");
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
If the record is not inserted after adding server validation, it indicates that the form is not validating properly.
You have added required validation to the terms field in your form.
If you do not put a value in the terms filed, no record will be inserted.
Make sure you are putting a value in the terms field, if you still have problems, please send the php page in a zip file so I can look at the code in context.
