Installing PAY PAL extension for Dreamweaver 8
Thread begun 11/24/2009 11:41 pm by derek394421 | Last modified 11/25/2009 8:30 am by Office Guy-172461 | 2864 views | 3 replies |
derek394421
After downloading and following the instructions to install, the extension will not install and I get no error message.
I also get this message, " The extension package is invalid, the extension will not be installed"
Office Guy-172461
Sometimes this can be fixed by restarting Extension Manager (make sure DW is closed when installing extension).
If that doesn't work, try downloading the extension again. Sometimes this error message pops up if you try to use the file before it has completely downloaded.
derek394421
Thanks Office Guy-172461,
I have tried both suggestions, but no luck.
I have two versions of Dreamweaver, 8 and CS4, perhaps there is a conflict, although the CS4 Extension Manager is not working and I am not able to uninstall and re-download.
Any ideas ?
Office Guy-172461
It sounds like this is your problem. You have to use the Extension Manager for your version of Dreamweaver.
See if anything here helps you remove Extension manger:
Solving problems with Dreamweaver
146/
