Error Capture & Multi-Language Support?
Thread begun 11/24/2009 7:57 am by BGordon | Last modified 2/27/2012 2:40 pm by Jason Byrnes | 4578 views | 7 replies |
BGordon
I have the latest version and have driving directions enabled. I use a form (like the recipe) to update the visitor's FROM address, city and country... Works great MOST of the time except when users enter a typo for any of the above.
I notice that with driving directions enabled, that if the visitor's 'from' location is not found, then the driving directions simple don't display at all... no errors or any feedback from Google.
Google must supply some kind of error code that can be tested against to show wording like "From location not found, please try again"...
Does your code support this or what can be added to my .php file to check for these returned error codes so I can show some error text in the driving direction div?
Also, I know Google supports passing a language variable in the call for the driving directions, I just don't know where to add the syntax...
Something like ",EN" or ",FR" I think...
Any ideas on either of these?
Thanks!
In the map js file, there is a function to capture directions errors:
GEvent.addListener(directions, "error", function() {
map.setCenter(wagmp_map_1_obj.points[0], 13);
map.addOverlay(wagmp_map_1_obj.markers[0]);
you could change that to:
<?php if($_SERVER["REQUEST_METHOD"] == "POST") echo("alert('The address you entered cannot be found');\r\n"); ?>
to show a javascript alert window.
you can change the language by adding an hl parameter to the API script tag.
For example, the tag will look like:
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAvZMU4-DFRYtw1UlTj_zc6hT2yXp_ZAY8_ufC3CFXhHIE1NvwkxQcT1h-VA8wQL5JBdsM5JWeJpukvw">/*wagmp*/</script>
I could change the map to german by adding "hl=de":
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAvZMU4-DFRYtw1UlTj_zc6hT2yXp_ZAY8_ufC3CFXhHIE1NvwkxQcT1h-VA8wQL5JBdsM5JWeJpukvw&hl=de">/*wagmp*/</script>
jogy_mac435394
Why not implemented language-setting?
the result in directions is babylonian giberish:
first line german: "12,1 km - ungefähr 17 Minuten"
all other:"1. Head north on Johann-Walling-Straße toward Kardinal-von-Galen-Straße
0,1 km" and so on...
I'm sorry, but i can't implement a german "hl=de".
In 2012 no api is requiered so i don't know where to include this variable.
Please give me hints to solve this.
Regards
please post a link where i can see the problem.
jogy_mac435394
map.php
in the map v3 API, it no longer uses the hl attribute, it now uses the language attribute.
change:
<script type="text/javascript" src="http://maps.googleapis.com/maps/api/js?sensor=false&hl=de&key=">/*wagmp*/</script>
<script type="text/javascript" src="http://maps.googleapis.com/maps/api/js?sensor=false&language=de&key=">/*wagmp*/</script>
jogy_mac435394
wow - thank you for this quick solution!
you're welcome.
