Search using dates and display the records/ total sales amount
Thread begun 11/24/2009 6:31 am by Suggs | Last modified 11/25/2009 11:28 am by Eric Mittman | 1449 views | 1 replies |
Suggs
Hi Folks,
What im wanting to achieve is this:
In my admin i want to build a feature where a user can search for orders between given dates and have them returned. I also want to be able to show the total amount in value of sales for this period as well.
Im using the MySQL timestamp in the database field to record the date and time of the order, and the following php to convert it to UK date/ time layout for the user to view... <?php echo date('d/m/Y,H:i:s',strtotime($row_Recordset1['OrderDate'])); ?>
The field for each order total is OrderAmount and this is what im wanting to count.
Any pointers will be greatly appreciated.
Cheers
To begin with you will need to have a recordset that select all of the records from this table, you will want to sum the OrderAmount column like this:
SELECT SUM(OrderAmount) AS OrderTotal FROM Orders
I go this from w3schools website, this is their example.
sql_func_sum.asp
Once you have the recordset setup like this on your results page you will want to make sure that you have your search page setup as well. Next you will apply the DataAssist Search server behavior to the results page. When you are configuring the search criteria you will specify the date column then the date type for the data, for the starting date criteria you would just specify the comparison as greater than, then for the end date you would do the same but choose less than.
Post back if you have any other questions or have any problems with any part of this.
