Menu too long to fit form
Thread begun 11/23/2009 5:57 pm by jc1cell390254 | Last modified 11/24/2009 4:29 pm by Jason Byrnes | 3377 views | 4 replies |
jc1cell390254
I just created a dynamic form menu and it's working great. Except :eek:.
When online, the menu is way too long. I know that the database record (field) is set to 80varchar and that's causing it. When I reduced it to an amount that would work, it truncated the data. So I lost that.
I have been able to get the table back from backup but I'm wondering how I can apply some css to the form menu inside dreamweaver so that when the menu is not selected it stays at a specific size and when it is selected it opens to the needed size?
Anyone has any ideas? I know I have seen it implemented on several sites.
jc
jc1cell390254
Go figure...
Although I didn't have to CSS, I found a workaround. Not sure if the only one but here goes.
I went into the table and looked at the largest name. Once I found it, I reduced it to a shorter size and that fixed the problem. Actually, it just brought the menu to the largest size again, except that it was reduced by me this time.
jc
PS. if you do have a css solution, please provide it.
You could apply the overflow: hidden; property to the element. using overflow: hidden will fit the menu to the container and hide whatever content does not fit.
jc1cell390254
Hey Jason,
I had tried that and it didn't work. I'm thinking I may not have had the proper specificity for it. I'll keep trying to see if I get it to work that way even though it's working with the other change I did to the table itself.
Thanks for the reply.
jc
If you need further help post a link, with design problems such as this, I can only give a theoretical answer if I cannot see the problem. If I can see the problem in the browser, I can usually give the exact fix.
