log in form
Thread begun 11/23/2009 6:18 am by berndrendic374326 | Last modified 11/25/2009 5:28 am by berndrendic374326 | 2676 views | 2 replies |
berndrendic374326
log in form
Hi everyone,
We are making a website that only our student should be able to use.
So we need in registration form an extra box,,, for student reg numbers .....
So when a new user tries to register, the first thing he needs to do is type his student number and if its incorect and does not match to any in our database , he is not allowed to register....
We need to make sure that only real student already members of the course use the website
Can someone please let me know how to do this.
Thanks in advance
Beri
Add the new Student number form element to the registration form.
then create a recordset that queries your table of student numbers, filter the student number column on the student number form element.
The code to insert the new rtegistration to the database looks like:
// WA Application Builder Insert
if (isset($_POST["Register_x"])) // Trigger
$WA_connection = $localhost;
$WA_table = "users";
$WA_sessionName = "users_UserID";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "UserID";
$WA_fieldNamesStr = "UserEmail|UserPassword|UserVerificationCode|UserIP";
$WA_fieldValuesStr = "".((isset($_POST["UserEmail"]))?$_POST["UserEmail"]:"")  ."" . "|" . "".((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"")  ."" . "|" . "".$_SESSION['randomConfirm']  ."" . "|" . "".((isset($_SERVER["REMOTE_ADDR"]))?$_SERVER["REMOTE_ADDR"]:"")  ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''";
$WA_fieldNames = explode("|", $WA_fieldNamesStr);
$WA_fieldValues = explode("|", $WA_fieldValuesStr);
$WA_columns = explode("|", $WA_columnTypesStr);
$WA_connectionDB = $database_localhost;
mysql_select_db($WA_connectionDB, $WA_connection);
  if (!
session_id()) session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = mysql_insert_id();
  if (
$WA_redirectURL != "")  {
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL, '?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
Add an if statement around that to check if the recordset is not empty:
<?php if (!($totalRows_CheckRepeat == 0)) { ?>
< insert record code block >
<?php } ?>
If you wanted to show an error message, add the following to the page:
<?php if (($totalRows_CheckRepeat == 0) && isset($_POST["Register_x"]) { ?>
The student number you entered does not exist.
<?php } ?>
berndrendic374326
Jason you are a star thats great Thanks :)
