Question on Log Out Page
Thread begun 11/22/2009 4:58 pm by jc1cell390254 | Last modified 11/24/2009 4:26 pm by Jason Byrnes | 4348 views | 7 replies |
jc1cell390254
Well, after days of not getting replies to this post in Data Assist from post 5 on and plenty of searching in the forum archives, I decided to trash everything I did with Form Builder and Data Assist and start over from scratch using Security Assist to create my registration pages and client area.
I'm amazed at how much simpler it is to apply the basics of the registration and the cookies functionality using Security Assist than using FB and DA. I couldn't find any documentation to help me with the proper functionality of cookies, sessions, etc. And although there's no true explanation on how to apply sessions to the registration in the Security Assist videos, only client side cookies, by looking at the options it seems like it could be the same steps. I'm not much to complain, I'd rather take action as I did, but I'm a bit disappointed at the lack of help I received for that specific situation.
A quick suggestion would be to work on improving your help videos and pdf's. A man can get lost easily in a country where the language is new and I can surely say I got plenty lost and fell into many pot holes. I almost gave up....but then again...I'm a hard head so I'm back for more.
Moving forward, I already have my registration and log in pages fully functional with cookies working rather well (haven't fully tested on hosting server, only on local virtual server). Although I haven't incorporated the profile page, emailpassword page or the client section page; I'm wondering how I would implement the log out page. I'm thinking it's a simple link to the page from any page I choose and that the php code within the log out page should take care of everything.
If anyone can point me in the right direction it would be great. I know I will probably be back when I implement the new project form and the milestone forms, but I'll do my best to try and figure it out with the least amount of posts here on the forum.
Cheers
jc
When you run the security assist wizard, if you have Cookies Toolkit installed, you have the option of Creating a log out page.
The logout page will have the Cookies Toolkit Clear Session Values server behavior on it. It will use the Before Page Load trigger and will be set to Clear All session variables.
jc1cell390254
I appreciate the response Jason. However, I already have the log out page created. I just wanted to verify if linking to the page was enough to make it do what it does (clear session).
I have confirmed such in another thread I found this morning. Thanks for the reply though, much appreciated.
jc
OK, you're welcome.
jc1cell390254
Sending time stamp on
Ok. Here's another one. Not sure if I should open a new thread so here goes.
I have a field for registration date in the client table. It's set to timestamp. After creating the registration form, there is no option for timestamp to send to the field in the insert record option so it gives me a null rather than a date and time.
I found this"
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "WAATKRegistrationForm")) {
$insertSQL = sprintf("INSERT INTO Clients (fk_country_t_country_id, ClientEmail, ClientPassword, ClientName) VALUES (%s, %s, %s, %s)",
GetSQLValueString($_POST['ClientLocation'], "int"),
GetSQLValueString($_POST['ClientEmail'], "text"),
GetSQLValueString($_POST['ClientPassword'], "text"),
GetSQLValueString($_POST['ClientName'], "text"));
Which I understand to be the server behavior that takes care of that and see nothing there mentioning this null value being sent. How can I get the timestamp in there?
jc
In the MySQL Database, set the Default value for the registration date column to NOW()
Currently, you are not inserting anything into that column when a new record is created. If you do not set a default value and do not insert anything , it use NULL.
jc1cell390254
Is that the same as
  CURRENT_TIMESTAMP
yup, they are the same thing.
