application
Thread begun 11/21/2009 7:15 pm by sturgisk383938 | Last modified 11/25/2009 6:28 am by sturgisk383938 | 4223 views | 7 replies |
sturgisk383938
application
I am have a problems with Universal Email. I am developing job application for my site. I have the search page, result page, detail page about the job. The next page is the application page. I want to let the user upload their resume and give them the option to cut and paste their cover letter on the application. I am following the direction to include attachments with your email form. I have upload the fillies to test them. I am not getting the email at all. I have some code from my page. If you need more let me know! Can someone help? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "resume/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "resume", "2", "[NewFileName]_[Increment]", "false", $WA_UploadResult1_Params);
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if ((isset($_POST["submit"]))) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
do {
$RecipientEmail = "".$row_application["id"] ."";include("WA_Universal_Email/WAUE_application_1.php");
} while ($row_application = mysql_fetch_assoc($application));
//Send Mail All Entries
if ("confirmation_page.php"!="") {
header("Location: confirmation_page.php");
In Universal Email, it looks like you are using the ID column from the recordset for the TO address:
the ID column will likely contain a Unique ID number for the record, you should select the column that contains the email address instead.
sturgisk383938
Application
I still not working. What should do?
sturgisk383938
Recordset?
I think also part of my problem is the recordset for the application page. My main goal is to let the user search, select, and apply. Now the user would fill out their name and email address and also upload their resume to the application. I am trying to use the email in the datebase from the employer. How should I set the recordset to accomplished this goal. In the past I have used the ID and the email for my columns in the recordsets. Is this the way to go? Is their a better way to get the email ?
How are you creating the recordset?
What fields are you searching on?
Can you send the entire page so I can see it in context.
sturgisk383938
I just started to get the email, but I don't have the resume attached. I tried to remove the server directory entry. Any other suggestions?
have you followed the "Sending Email Attachments with Digital File Pro and Universal Email" tutorial?
it is located in the how To section of the DFP support page:
digital-file-pro/
sturgisk383938
Following Directions
yes, I will take another look from start to finish.
