Multiple filter options - ASP
Thread begun 11/21/2009 2:41 pm by webmaster364567 | Last modified 11/25/2009 4:46 pm by Jason Byrnes | 3117 views | 3 replies |
webmaster364567
Hi.
I have notised that the wizard only can filter one option and have changed the codes in the (filenane)_data(number).asp file so that the recordset will filter the results with three options (filter) like this
WHERE field = paramfield AND field2 = paramfield2 AND field3 = paramfield3.
All the three parameters get their values from Request.QueryString("formelement") .
I have tested the recordset and it works with the option of filtering three values.
But when I upload all the files it seems like only the first filter option works and not the next two. I can change the value in the url and the first filteroption works but not if i change the two last filteroptions in the URL.
I know with certanty that the filteroptions in the recordset works and the connection code is correct - but where is it that the two last filteroptions are dropped out?
Please send a copy of the (filenane)_data(number).asp file you edited so we can see how the recordset is configured.
webmaster364567
Kode
Dim WADWCchlaas_medklindb_jegkanelev__MMColElevID
WADWCchlaas_medklindb_jegkanelev__MMColElevID = "157"
If (Request.QueryString("elevid_form") <> "") Then
WADWCchlaas_medklindb_jegkanelev__MMColElevID = Request.QueryString("elevid_form")
End If
Dim WADWCchlaas_medklindb_jegkanelev__MMColFagID
WADWCchlaas_medklindb_jegkanelev__MMColFagID = "1"
If (Request.QueryString("jegkanfag_id") <> "") Then
WADWCchlaas_medklindb_jegkanelev__MMColFagID = Request.QueryString("jegkanfag_id")
End If
Dim WADWCchlaas_medklindb_jegkanelev__MMColTrinnID
WADWCchlaas_medklindb_jegkanelev__MMColTrinnID = "1"
If (Request.QueryString("jegkantrinnid") <> "") Then
WADWCchlaas_medklindb_jegkanelev__MMColTrinnID = Request.QueryString("jegkantrinnid")
End If
Dim WADWCchlaas_medklindb_jegkanelev_cmd
Dim WADWCchlaas_medklindb_jegkanelev_numRows
Set WADWCchlaas_medklindb_jegkanelev_cmd = Server.CreateObject ("ADODB.Command")
WADWCchlaas_medklindb_jegkanelev_cmd.ActiveConnection = *connectionstring*
WADWCchlaas_medklindb_jegkanelev_cmd.CommandText = "SELECT jegkannr AS XLABEL, fk_vurdering_id AS YVALUE, fk_jegkan_id, fk_elev_id, jegkanelev_id, dato_vurdert, jegkan_id, jegkanfag, jegkantrinn, jegkantekst FROM chlaas_medklin.db_jegkanelev INNER JOIN chlaas_medklin.db_jegkan ON fk_jegkan_id = jegkan_id WHERE fk_elev_id = ? AND jegkanfag = ? AND jegkantrinn = ?"
WADWCchlaas_medklindb_jegkanelev_cmd.Prepared = true
WADWCchlaas_medklindb_jegkanelev_cmd.Parameters.Append WADWCchlaas_medklindb_jegkanelev_cmd.CreateParameter("param1", 5, 1, -1, WADWCchlaas_medklindb_jegkanelev__MMColElevID) ' adDouble
WADWCchlaas_medklindb_jegkanelev_cmd.Parameters.Append WADWCchlaas_medklindb_jegkanelev_cmd.CreateParameter("param2", 5, 1, -1, WADWCchlaas_medklindb_jegkanelev__MMColFagID) ' adDouble
WADWCchlaas_medklindb_jegkanelev_cmd.Parameters.Append WADWCchlaas_medklindb_jegkanelev_cmd.CreateParameter("param3", 5, 1, -1, WADWCchlaas_medklindb_jegkanelev__MMColTrinnID) ' adDouble
Set WADWCchlaas_medklindb_jegkanelev = WADWCchlaas_medklindb_jegkanelev_cmd.Execute
WADWCchlaas_medklindb_jegkanelev_numRows = 0
That looks correct, the only thing I can think is that your changes are not being uploaded to the server correctly.
Try deleting that page off of the server then uploading it again to make sure the changes are being uploaded.
if you continue to have problems, please send a link so I can take a look.
