DA Error
Thread begun 11/20/2009 5:10 pm by Paul | Last modified 1/19/2010 2:53 pm by Jimmy Wu | 5484 views | 11 replies |
PaulBeta Tester
DA Error
Running DA 2.0.6 on Windows 7 CS4.
It appears that installing WA HTML editor into CS4 has somehow corrupted Data Assist. (This could well be coincidental tho)
Now, when running DA wizard, I'm receiving the following
While executing OnLoad in WA_AppBuilder.htm, the following javascript error ocurred.
In file "WA_AppBuilder":
InitilaizeUI is not defined
Can anyone provide a fix?
Thanks, Paul.
Jimmy Wu
Try following the steps outlined in the "Common Installation Issues" document:
PaulBeta Tester
Thanks Jimmy,
Tried variants of uninstall/reinstall and wincache delete, none unfortunately resolved the issue.
I've even tried creating new config folder with just a previous ver in installed.
Paul
Jimmy Wu
So you've tried renaming the configuration and installing only DataAssist and the error still occurs? It could be related to Windows 7, since we have not started testing on that platform yet. Were you able to get it working on Windows 7 before installing HTML Editor?
PaulBeta Tester
Jimmy,
Yes, I have this running on another instance of Windows 7 where the editor is not installed.
Paul.
Jimmy Wu
Try uninstalling both extensions and installing HTML editor first before installing DataAssist to see if the HTML editor being installed afterwards is causing the issue.
PaulBeta Tester
I un-installed both extensions, then..
1. Installed HTML Editor 1st then DA
2. Uninstalled both again
3. Installed DA on its own.
Both tests failed to resolve the initial problem.
Screenshot of error dialogue attached.
Jimmy Wu
It appears that your configuration folder may have been corrupted. Here is a post that explains how you would get rid of the corruption:
showpost.php?p=12293&postcount=2
Try those steps and repeat the above installs and see if the error still occurs.
PaulBeta Tester
Originally Said By: Jimmy Wu
Jimmy,
I tried exactly as you suggested.
Unfortunately, this did not resolve the initial issue.
Regards, Paul
Jimmy Wu
After renaming the configuration folder, which extensions did you install? Are the other extensions still working as expected?
