Bubble shows without directions, but not with
Thread begun 11/20/2009 3:05 pm by WilliFixit | Last modified 11/23/2009 2:58 pm by Ray Borduin | 2409 views | 4 replies |
WilliFixit
Today I decided to add the directions for a Google Map. When I enabled the Include Directions in step 5 of the WA interface, then I lose the bubble on the main (only one) map point just as the map loads. If I disable the Include Directions, it comes back.
How do I enable the directions AND get the bubble to show?
Thanks,
Are you gathering the origin location for the directions on the same map page? If so and you would like the normal map to show until the address is entered you could have two maps on the page, one with the directions enabled that won't display unless the user enters the location, and the other would just be the normal map.
If you need to have just the single map but have it change to the directions map only after a user enters the directions you may need to add in a little custom code to get the map to display like this.
Do you have a link to the page with the map on it? I think having a reference for your current setup would be helpful.
WilliFixit
Link and answer
Yes, the map and form for putting in the directions are on the same page.
See: ourlocation.php
jon_upton
Problem appears to be with form submit...
I have tried your page a couple of times the form doesn't submit because regardless of whatever you enter it fails your validation even your selection from the state list fails
see attached image.
If the form doesn't submit then promaps can't create the driving instructions.
Best regards
Jon
You can try updating this line the two places it occurs:
if(!fromAddress.enabled || 'address_0' != 'address_0') {
update it to:
if(fromAddress.street == '' || 'address_0' != 'address_0') {
I think that will fix it.
