Error message in security assist wizard
Thread begun 11/20/2009 10:46 am by xberniex250371773 | Last modified 11/20/2009 11:23 am by Jason Byrnes | 1348 views | 1 replies |
xberniex250371773
I'm getting a error message when I click next on the security assist on step 1 to go to step2. Error message states the following..
An error has occurred in the script on the page
*Line:643
*Char:1
*Error:object expected
*Code:0
*Url:
What is the problemo?
Also do I need to bind the DB to my Template page?
On page one are you selecting a template?
If yes, It sounds like your template has a javascript error in it. you will need to correct this script error before using it in Security Assist.
Or you could disable preview in the WebAssist Preferances. Go to Edit -> WebAssist Preferances and check the disable preview option.
What happens if you do not select a template?
