Web validation problem / zoom
Thread begun 11/20/2009 2:27 am by brunodarwin371999 | Last modified 11/21/2009 1:16 am by brunodarwin371999 | 44909 views | 2 replies |
brunodarwin371999
I have a small problem with validation of my template page...
My Webassist "Jeffrey Zeldman's web standards advisor" extension advises that there is a problem in the file
CSSMenuWriter/cssmw/menu_ie.css
The error message is >>> CSS validation - property zoom doesn't exist <<<
And the problem comes with the instruction "zoom:1;".
How can we fix the problem so that all my template is ok with XHTML 1.0 STRICT.
Thanks in advance.
anonymous
Hi there,
There is a good discussion about that here:
1354-The-Power-Of-ZOOM-Fixing-CSS-Issues-In-Internet-Explorer.htm
I have found, myself, that Zoom is good for forcing IE to obey Alpha commands... naturally with later versions of IE, this is not as much a problem - so you could probably eliminate Zoom if you are not concerned about IE6. I am not sure about IE7 response... but it may be worth testing without Zoom.
The thing to keep in mind is that Zoom is ONLY recognized by IE - so naturally, standards based validation is going to not like the command.
Best regards,
Brian
brunodarwin371999
Thank you very much SOJO for your answer.
