CSS Menu Writer 2 Pre Purchase Questions
Thread began 11/19/2009 1:30 pm by kenholden1394203 | Last modified 11/20/2009 9:31 am by Jason Byrnes | 1208 views | 1 replies |
kenholden1394203
Hello,
I'm in the process of porting my GoLive website over to Dreamweaver and would like to recreate the existing navbar menu from GoLive to Dreamweaver using CSS Menu Writer 2. The original navbar was created in MenuMachine2 which is not available for Dreamerweaver.
For reference here is the URL to my website, www.kenholden.com. To view the horizontal navbar and drop-down menus, select BODIES-of-WORK / de Young Museum Project. Here are a few of my questions:
1. Does CSS Menu Writer 2 have the capability to replicate this style of menu, i.e., horizontal, including multiple sub-horizontal menus?
2. Can CSS Menu Writer 2 fine tune text buttons independent of a fixed width? If I use a fixed width often the spacing between words is too large because the width is applied as a fixed spacing and not based on word length/character length.
3. Can the navbar be created without boarders?
4. Can fine tuning control be achieved for each text button? For example, word spacing, text color, font size, etc.?
5. How much navbar page positioning is there, i.e., off-sets from center, or left/right?
6. For drop-down or flyout menus, is there horizontal and vertical positioning control available?
I appreciate your help and any other advice you can provide that explains the features available in CSS Menu Writer 2 so that I can make a purchase decision. Thanks!
Regards,
Ken
1) No, CSS Menu Writer does not have the capability off crating a horizontal menu with horizontal sub menus.
2) The menu writer interface will apply the same width to all of the menu items. Inline styles can be applied to each menu item after the menu has been created to fine tune the widths of each item, but this must be done manually.
3) Yes, the nav bar can be created with out borders.
4) This sort of control must be accomplished using inline styles on each menu item after the menu is created similar to widths in question 2.
5) You do not control the nav bar positioning in menu writer. The menu should added to a navigation div on your page. The menu position is controlled by positioning the navigation div element.
6) The sub menus in a horizontal menu will drop down. In a vertical menu, they will fly out.
