Cannot update or insert
Thread begun 11/19/2009 10:23 am by J7HNW | Last modified 11/19/2009 10:45 am by Jason Byrnes | 1369 views | 1 replies |
J7HNW
Hi
Data is on this link and is only dummy data
barchester_results.asp
I can Search, View resultslist, View details, Delete a product no problem
I cannot Update a product or Insert a product.
The code query appears to be correct - eg barchester_Update.asp?ID=5 requesting the update page via the ID which is the key column.
Please help
Regards
It looks like you are using some reserved words for column names in your table, for example "date". date is a function in Access (and other) Databases to return the currant date, it should be avoided as a column name.
The following web page has a list of words that are reserved by MS Access, these words should not be used for column names in your database.
286335
