Need a simple date/time hidden field
Thread begun 11/19/2009 8:45 am by ijk76319396 | Last modified 11/19/2009 11:06 am by CraigR | 4029 views | 4 replies |
ijk76319396
What is the easiest way to insert a hidden field for entry into PHP database that enters the current time and date according to MY local timezone. I am familiar with the 'current timestamp' function in PHP my admin, however this displays the date in a YEAR/DAY/MONTH format with 24 hour time. I want it to read much simpler as in Day, Month, Year 3PM(example)
so what do I need to do?
CraigRBeta Tester
if you timestamp fulfils your need, but you just want it to be prettier visually, you can either...
format the date field within the SQL statement
OR
format the date field in PHP, eg
<?php echo date('d/m/Y',strtotime($row_recordset['datefield']));?>
you can extract just the day, month, year or whatever you want to display.
neilo
That is the answer. If you want to further configure it for your timezone (or in any other way) check out OG's kb article:
17/
ijk76319396
Originally Said By: CraigR
This option shows me everything except for the time field. Any ideas why?
CraigRBeta Tester
the posted string returns day/month/year
look at the link posted by neilo to get php to return what you need
eg for year only, try
echo date('Y',strtotime($row_recordset['date_field']))
