content is at the bottom of the page?
Thread begun 11/19/2009 7:44 am by JBWebWorks | Last modified 11/20/2009 6:23 am by neilo | 4407 views | 7 replies |
JBWebWorks
Using CSS Sculptor version 3.0.0
design is 3 Column liquid Header and Footer
Problem-- on a couple of pages in design view, the content div is at the bottom of the page beneath the left and right column. In browser view on my pc, it displays properly but on another pc it displays at the bottom of the page.
On other pages, it is not a problem, just on the 2 pages?
settings are
#outerWrapper {
background-color: #fff;
margin: 0 auto 0 auto; /* Sets the margin properties for an element using shorthand notation (top, right, bottom, left) */
text-align: left; /* Redefines the text alignment defined by the body element. */
width:100%;
min-width:1200px;
border:solid 10px #009933;
#outerWrapper #contentWrapper #rightColumn1 {
background-color: #ffff00;
border-left: none 1px #a8a2d1; /* Sets the left border properties for an element using shorthand notation */
float: right;
height: 2500px;
padding: 10px 10px 10px 10px; /* Sets the padding properties for an element using shorthand notation (top, right, bottom, left) */
width: 20%;
#outerWrapper #contentWrapper #leftColumn1 {
border-right: none 1px #a8a2d1; /* Sets the right border properties for an element using shorthand notation */
float: left;
height: 2500px;
width: 20%;
/* Contains the main page content. When using a mutliple column layout the margins will be set to account for the floated columns' width, margins, and padding. */
#outerWrapper #contentWrapper #content {
margin: 0 22% 0 22%; /* Sets the margin properties for an element using shorthand notation (top, right, bottom, left) */
height:2500px;
attached is an image of my screen in design view using dreamweaver cs4
neilo
Using the css you provided on a 3 Column liquid Header and Footer CSSS page, I can't seem to reproduce your problem. Is it possible to provide the code between the body tags of one of the faulty pages?
JBWebWorks
thanks for your response.
the entire content on the main page is in a table 100% width cellspacing 5 two columns and 5 rows.
Using properties in DW CS4 i had the table align to center. I just changed it to align default and i think it solved the problem for that page because in design view the content went to the top of the content div?
here is the page
www.bubbasmobileyardsales.com
the other page is
sponsor-information.php
it has a table in the content which is set 100% width cellspacing 5 two columns (1 column 410px width) two rows.
I'm not able to reproduce a problem viewing the page in FireFox, IE7 or 8 and Safari. I have tried viewing the page on 4 different computers using both windows and mac.
JBWebWorks
thanks Jason for your help.
I don't know why but changing the table from align="center" to align=default fixed the problem.
in design view
with <table align="center>
with <table>
OK, Glad to hear you have it working.
Miguel
You can also do a trick there to have your table aligned, i had that rpoblem before and was when i used tables with 100% if you change it to 99% it wont go down either
neilo
Hi JB,
Must admit that I'm al ittle confused as to why you are using CSS Sculptor to fashion the page, when its component parts and css functionality has largely been replaced by tables.
I may be missing something, but might this not be a good time to switch to a (near) fully css site?
