hiding the info bubble on load
Thread begun 11/19/2009 6:48 am by enquiries281871 | Last modified 11/20/2009 12:54 pm by Jason Byrnes | 3685 views | 5 replies |
enquiries281871
Is there a way of hiding the info window bubble of the default address when the map loads? - it currently hides lots of other makers (I'm using multiple address from a recordset) and I'd prefer if it were turned off by default unless a user clicked the marker.
I'm using ASP if that helps.
Thanks in advance.
See the following post for information on accomplishing this:
showpost.php?p=28050&postcount=4
enquiries281871
I tried doing a search for "marker_0_0.openInfoWindowHtml" (in wagmp_map_1.asp) but found no matches (as suggested in the other post). Is it because I'm using multiple addresses from a database recordset? because I do have entries such as:
if('address_0_<%=CStr(rsLocations_1_0_repeat_index)%>' == 'address_0_0')
marker_0_<%=CStr(rsLocations_1_0_repeat_index)%>.openInfoWindowHtml(address_0_<%=CStr(rsLocations_1_0_repeat_index)%>.infowindowtext);
(where rsLocations is the name of my recordset)
Yes, those lines should be commented, the syntax is slightly different because you are using a recordset.
most likely you could search for just:
openInfoWindowHtml
to find the lines that need to be commented.
enquiries281871
Thanks, that did the trick.
excellent, glad to hear it is working.
