Testing Server and Hosting Server Syncronization
Thread began 11/18/2009 11:22 am by koneill385535 | Last modified 11/18/2009 12:03 pm by neilo | 1650 views | 4 replies |
koneill385535
I am trying to sync my testing server and my hosting server so that I don't have to change the connections file everytime I upload my site. How do I change the hostname on my testing server? Isn't it automatically localhost?
CraigRBeta Tester
You hosting server should provide you with the ip address and password of your hosted database.
so, if your local connections file, connectionname.php looks something like this...
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_connectionname = "localhost";
$database_connectionname = "NAME";
$username_connectionname = "root";
$password_connectionname = "PASSWORD";
$connectionname = mysql_pconnect($hostname_connectionname, $username_connectionname, $password_connectionname) or trigger_error(mysql_error(),E_USER_ERROR);
create a duplicate file called (for example) connectionname_live.php and put the correct info in.
# Type="MYSQL"
# HTTP="true"
$hostname_connectionname = "0.0.0.0";
$database_connectionname = "databasename";
$username_connectionname = "connectionname";
$password_connectionname = "password";
$connectionname = mysql_pconnect($hostname_connectionname , $username_connectionname , $password_connectionname ) or trigger_error(mysql_error(),E_USER_ERROR);
publish this file to the remote, hosting server, than rename it
koneill385535
Uh oh
I tried doing what you said and I must have done something wrong. I had some errors and I tried to fix them, but what I ended up doing screwed up both my connections files. I would tell you what the issue is, but I don't really know. I think I need to open a support ticket.
neilo
The likelihood is that 'localhost' would be the hostname.
Have to admit that I'm not sure why people choose to test database locally; unless you are in a wi-fi dead-zone.
I set only one connection per site with hostnames as 'www.mysitenames.co.uk' and the db, username, password as you have them. Set my hosted databases to accept my referral.
Set and forget!
neilo
Sorry, apart from the first line, my last post was irrelevant.
Just to be clear, have you tried:
# Type="MYSQL"
# HTTP="true"
$database_connectionname = "Any Connection Name";
$username_connectionname = "YourDB_Username";
$password_connectionname = "YourDB_Password";
With the right Username and Password for your (live) database, this would normally do it.
The "Any Connection Name" would need to be the same as the one you've referred to in your pages (if you have already created dynamic content!)
