Possible cross site scripting
Thread began 11/17/2009 1:31 pm by larry268887 | Last modified 2/03/2014 8:15 am by John | 4205 views | 4 replies |
larry268887
I'm trying to get my site PCI compliant and am working with security metrics. They scaned my site www.elvisyorkshireterrier.com and found that I wasn't in compliance because there was possible cross site scripting. Possible cross site scripting was described as being able to attact a site by adding a script at the end of an address. As an example this is an address of one of my detail pages on my site miniature_yorkie_puppy_for_sale.php?Id=10 and if one would type "><script>alert(123)<%2Fscript>" at the end of the address if there isn't cross site scripting then nothing will happen and if there is cross site scripting then a box will pop up and display 123. My detail pages are php and I use web assist extensions. This only occurs on detail pages.
Here is exactly what they said
Possible cross site scripting on pet-sup plies/dog_clothes_accessories.php Use the following commands to verify this: wp --inject "http://elvisyorkshireterrier.com/pet-su pplies/dog_clothes_accessories.php?Categor yId=6%22%3E%3Cscript%3Ealert%28123%29%3C%2 Fscript%3E" curl -L "http://elvisyorkshireterrier.com/pet-su pplies/dog_clothes_accessories.php?Categor yId=6%22%3E%3Cscript%3Ealert%28123%29%3C%2 Fscript%3E"| grep "123" This website may have other injection related vulnerabilities.
I have no idea how to correct the problem. I have another site hosted with the same hosting company and was made the same with web assist extensions and passed the scan.
Larry
Just turn off error reporting. The problem is that when the error is reported it writes to the page, opening the cross site scripting vulnerability.
It is best to leave error reporting turned off on live web sites except when debugging.
larry268887
I had the error reporting turned off and it still is giving the error.
After the 123 window pops up and you close it this is the error I get
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '\">\"' at line 1
The error reporting must be turned on, or else it wouldn't be reporting that error to the page. Where did you turn off error reporting?
Update your php.ini, or add to the top of that page:
<?php ini_set('display_errors', 0); ?>
John
Scripts
My friend has the same thing but he says his site gets through just fine. I don't know why though he may be using a program that is unrelated to help him and won't tell me because I have done the same thing as him and used the same programs but not been able to get through. I'm not really heavily educated with the concept so if you get any more information let me know.
John Bond | http://www.artistryyorkies.com/yorkie-puppies.aspx#.UscknieJ7Dw
