data assist ecart & search
Thread begun 11/17/2009 11:02 am by chaintm153675 | Last modified 11/19/2009 2:25 pm by chaintm153675 | 2660 views | 5 replies |
chaintm153675
When using the below code and attempting to add a cart button, it seems to mess up the whole process. Concept here is simple, I need to add a search to a page like this...
product_search.php
to pages that have the cart like this...
product_moonjump_gen.php
however this is the page done so and errors...
product_searchtmp.php
which currently supports the ecart system. However, if I attempt to add a search function to this using data assist. I get nothing but errors, so then I went ahead and below started fresh with the search first then adding the cart next. From what I can tell, it seems that the cart doesn't like the fact I am using a search function within the recordset that is changed from your standard recordset. While I thought about using a different recordset, the issue then would be how to ID that with the colums and rows which as you know you can't do. So in this, how do I tie a cart to a search result? Is that even possible with webassist products? If not, I guess this means hardcoding?
Here are some pages you can look at that have the search feild intact, please ignore the graphics as well for obvious reason, search box is on top right, just enter anything and press enter. I want that type of searching (got the indexing and paging down) but with the above mentioned add item to cart button. Seems farly simple, but sadly nothing but issues.
I will be adding this search feature throughout this site.
There are no pages attached to your post.
can you provide the text of the errors you are running into?
and a copy if the page where the errors occur.
chaintm153675
well the code for each page is large, not sure what pages are not showing? You mean the one with the error? ya, it just lockes up sadly.. and this forum has limits beyond text, but for your access here is a new link with the text copy of the code.
code.txt
chaintm153675
attached is some files in zip, you forums sadly is very limiting to posting stuff. So if you need certain files let me know, IE if you want a dump or a copy of scripts whatever.
product_ride.php works fine as is, that is currently whats on the site.
product_search.php has the issue after adding a cart.
product_searchbck.php has no issue when searching but has no cart.
product_searchtmp.php you know, i don't know whats on that, probably an older build but it might help by referance.
the current page... product_search.php actually on site atm works as i want the search to work, the product_search.php you have is after adding the cart, it just fubars the whole thing, also as many have posted here, when u attempt to change , add or do anything to the recordset you sometimes get the "cant change the recordset" but if you do the search first and cart addition second you can change it then but ofcourse it doesn't work because the code within is tied togather. IE the
SELECT *
FROM items
WHERE ItemName LIKE ""
ORDER BY ItemName ASC
which ofcourse dreamweaver hates. Eh, if you need any info or want to talk on the phone, im at work till 6pmcst.
I dont understand what you mean by "it just fubars the whole thing".
Does the page not run in the browser?
Do you get an error message?
can you give some mode details beyond "it just fubars the whole thing" so I can understand the issue you are experiencing to try and offer a solution.
please be as descriptive as possible. Also if you could upload the problem page to the server so I could see the issue in a browser, that would be helpful.
chaintm153675
Found the issue and fixed.
The script is not placing the cart php data tie in correctly. It puts it in the location that you you select to put the "add cart button" so a section. Moving the
//WA eCart Include
require_once("WA_eCart/MoonJumpCart_PHP.php");
to the top of the page above the
$MoonJumpCart->GetContent();
solved this issue, don't know why I kept missing this. so in the end...
my script looks like this now...
<?php require_once('Connections/mjconn.php'); ?>
//WA eCart Include
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: mjrslistprod;
//Searchpage: ;
//Form: ;
$WADbSearch1_DefaultWhere = "";
if ((((isset($_POST["search"]))?$_POST["search"]:"") != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr1 = array("ItemName");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["search"]))?$_POST["search"]:"") ."","OR","Includes",",%20","%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_product_search"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_product_search"]) && $_SESSION["WADbSearch1_product_search"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_product_search"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$maxRows_mjrslistprod = 6;
$pageNum_mjrslistprod = 0;
if (isset($_GET['pageNum_mjrslistprod'])) {
$pageNum_mjrslistprod = $_GET['pageNum_mjrslistprod'];
$startRow_mjrslistprod = $pageNum_mjrslistprod * $maxRows_mjrslistprod;
mysql_select_db($database_mjconn, $mjconn);
$query_mjrslistprod = "SELECT * FROM items";
setQueryBuilderSource($query_mjrslistprod,$WADbSearch1,false);
$query_limit_mjrslistprod = sprintf("%s LIMIT %d, %d", $query_mjrslistprod, $startRow_mjrslistprod, $maxRows_mjrslistprod);
$mjrslistprod = mysql_query($query_limit_mjrslistprod, $mjconn) or die(mysql_error());
$row_mjrslistprod = mysql_fetch_assoc($mjrslistprod);
if (isset($_GET['totalRows_mjrslistprod'])) {
$totalRows_mjrslistprod = $_GET['totalRows_mjrslistprod'];
} else {
$all_mjrslistprod = mysql_query($query_mjrslistprod);
$totalRows_mjrslistprod = mysql_num_rows($all_mjrslistprod);
$totalPages_mjrslistprod = ceil($totalRows_mjrslistprod/$maxRows_mjrslistprod)-1;
$queryString_mjrslistprod = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_mjrslistprod") == false &&
stristr($param, "totalRows_mjrslistprod") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_mjrslistprod = "&" . htmlentities(implode("&", $newParams));
$queryString_mjrslistprod = sprintf("&totalRows_mjrslistprod=%d%s", $totalRows_mjrslistprod, $queryString_mjrslistprod);
// WA eCart AddToCart
if (isset($_POST["MoonJumpCart_1_ATC"]) || isset($_POST["MoonJumpCart_1_ATC_x"])) {
$ATC_itemID = $_POST["MoonJumpCart_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "cart.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_mjrslistprod) && $totalRows_mjrslistprod > 0) {
$row_mjrslistprod = WAEC_findRecordMySQL($mjrslistprod, "ItemID", $ATC_itemID);
if ($row_mjrslistprod) {
$ATC_itemName = "".$row_mjrslistprod['ItemName'] ."";// column binding
$ATC_itemDescription = "".$row_mjrslistprod['ItemShortDesc'] ."";// column binding
$ATC_itemWeight = floatval("".$row_mjrslistprod['ItemWeight'] ."");// column binding
$ATC_itemQuantity = "".$_POST["MoonJumpCart_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_mjrslistprod['ItemPrice'] ."");// column binding
$ATC_itemSize = "".$row_mjrslistprod['ItemSize'] ."";// column binding
$ATC_itemThumbpic = "".$row_mjrslistprod['ItemThumb'] ."";// column binding
mysql_data_seek($mjrslistprod, 0);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$MoonJumpCart->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemSize, $ATC_itemThumbpic);
if ($ATC_RedirectAfter != "" && $MoonJumpCart->redirStr == "") {
$MoonJumpCart->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($MoonJumpCart->redirStr != "") {
header("Location: ".$MoonJumpCart->redirStr);
Which is correct and works perfectly.
