Keep HTML from being entered into database via a text field
Thread begun 11/17/2009 9:04 am by ijk76319396 | Last modified 11/18/2009 8:09 am by ijk76319396 | 4363 views | 8 replies |
ijk76319396
I need to prohibit the entry of HTML into my database by users to my website. Right now they can enter HTML into a text area I use as a comment box then it shows up when the record is displayed. I was told about a strip_tags function but I don't know exactly where to place it. Is there a function in Data Assist that does this automatically?
Jimmy Wu
You can run the strip_tags on the value being inserted into the database. So whatever is being inserted, you can call strip_tags on it right before its getting inserted.
ijk76319396
This is the value I have going into the database
<?php echo ((isset($_POST["commentsbox"]))?$_POST["commentsbox"]:""); ?>
Where exactly do I put the strip_tags and how should it look.
Jimmy Wu
You would put the call around the second $_POST["commentsbox"] in that line of code.
ijk76319396
This is the code I am typing into the source that Data Assist generates
((isset($_POST["commentsbox"]))strip_tags ((?$_POST["commentsbox"]:""))
Obviously I am making an error because I am getting the 'unexpected T_string error.
Dave BuchholzBeta Tester
you have to many ")" your code should look like this:
((isset($_POST["commentsbox"]))strip_tags (?$_POST["commentsbox"]:""))
ijk76319396
I entered that code and now I get the error
Parse error: parse error, unexpected T_STRING in C:\Inetpub\vhosts\comicracy.ieasysite.com\httpdocs\0111\6-cc.php on line 127
Here is the full block of code that Data Assist Generates with the strip tags added
// WA Application Builder Insert
if (isset($_POST["submit"])) // Trigger
$WA_connection = $con2com;
$WA_table = "comments";
$WA_sessionName = "comments_ID";
$WA_redirectURL = "../messagesent.php";
$WA_keepQueryString = true;
$WA_indexField = "ID";
$WA_fieldNamesStr = "USERNAME|COMMENTER|PAGE|COMMENTS|USERIDENT|COMMIDENT";
$WA_fieldValuesStr = "".$row_Recordset1['username'] ."" . "|" . "".((isset($_POST["COMMENTORNAME"]))?$_POST["COMMENTORNAME"]:"") ."" . "|" . "".((isset($_POST["website"]))?$_POST["website"]:"") ."" . "|" . "".((isset($_POST["commentsbox"]))strip_tags (?$_POST["commentsbox"]:"")) ."" . "|" . "".$row_Recordset1['ID'] ."" . "|" . "".((isset($_POST["ICON"]))?$_POST["ICON"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_con2com;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
apologies the code should read:
((isset($_POST["commentsbox"]))?(strip_tags($_POST["commentsbox"])):"")
ijk76319396
That did the trick. Thank you very much!
