Promotional Codes not working
Thread begun 11/17/2009 7:25 am by larsentim278054 | Last modified 11/17/2009 2:13 pm by Jason Byrnes | 3489 views | 5 replies |
larsentim278054
I followed the tutorial you have for creating a promotional code - and uploaded the revised cart.php as well as the WA_Store_cart.php file that the ecart program modifies but the promotional code doesn't work. It seems to not be triggering with the button (it doesn't do anything). However, it DOES work when I hit [ENTER] after typing in the coupon code, so it seems to be setup correctly, except for the button trigger. It doesn't do anything. I've copied all the code that was added to my cart pages below. I assume it's a problem with my form and something not identified correctly? Thanks!
Oh - and also, is there a way to have this promotional code only work on CERTAIN products? Instead of on the entire order? Thanks!
This is on my cart.php:
if((((isset($_POST["txtPromoCode"]))?$_POST["txtPromoCode"]:"") != "")) {
$_SESSION["PromoCode"] = "".((isset($_POST["txtPromoCode"]))?$_POST["txtPromoCode"]:"") ."";
And this is the form I added to the cart.php:
<form action="" method="post" name="PromoCode">
<table>
<tr>
<th><label for="txtPromoCode">Coupon Code:</label></th>
<td><input name="txtPromoCode" type="text" id="txtPromoCode" /></td>
<td><input id="couponCodebtn" name="txtPromoCode" type="button" value="" /></td>
</tr>
</table>
</form>
And this is the code that was added on my wa_store_cart_PHP.php:
//Discounts
$this->Discounts[] = new WA_eCart_Rule(urldecode("Promotional%20Discount"), true, "WAEC_WA_Store_Cart_PromotionalDiscount");
and
//eCart Rule
function WAEC_WA_Store_Cart_PromotionalDiscount() {
$totalDiscount = 0;
if (true && ((sizeof($this->Items) > 0) && ((isset($_SESSION['PromoCode'])?$_SESSION['PromoCode']:"") == "WebAssist"))) {
$totalDiscount += ($this->TotalColumn("TotalPrice") * 0.10);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
your text field and submit button are both named txtPromoCode:
you must us unique names for each form element.
try changing the submit button to:
<input id="couponCodebtn" name="couponCodebtn" type="submit" value="Submit" />
see this thread:
showthread.php?t=7503
for info on applying the discount only to certain items.
larsentim278054
I knew it was something stupid like that. Thank you very much for pointing that out.
About the individual items discounted - I read that thread, and replied on that thread with my questions. But should I reply on this one? Or keep it there. Not sure what would be preferred.
larsentim278054
I was just about to test this, so I went on my site. I'm not logged in, and there's nothing in my cart. So I added something to the cart. But when it went to the cart, there was already a discount showing on the product and I didn't add any coupon code! I assume it was there because I was playing with this earlier, but I don't understand this. I've since removed the coupon code (by making it inactive) - and then I fixed the form, made the discount active, uploaded the files, and proceeded to go to the site, and it's showing the discount already? Without any coupon code being added. So I assume the session variable is still in my browser or whatever... Why wasn't it removed? Why would it stick like that? How do I prevent this from happening? Is there a code I need to put on the cart.php page to remove the session variable or something? I just added this item to the cart... didn't add a coupon code...
larsentim278054
It seems to do this no matter when I enter a coupon code. If it's entered (which by the way, it still won't work with the button - I have to enter it and hit [enter] for the coupon code to work) -- I can clear my cart, add a different item to the cart, and the discount shows up again without me entering any code.
EDIT: I got the button to work. It had to be "submit" type. In your video tutorial, it says it should be type="button". When I switched it to submit, it works fine now.
Regarding the discount showing up - the only way I can get rid of it is by clearing my cookies. Is it supposed to act like this?
Yes, the discount code is stored in a session variable. A session variable will exist until the browser is closed completely or the cookie is deleted.
