Blank update deletes file
Thread begun 11/17/2009 5:35 am by John Langer | Last modified 11/18/2009 2:43 pm by John Langer | 5363 views | 7 replies |
John LangerBeta Tester
Sorry to jump on the band wagon with this but I too am having problems in retaining an existing file upload that's inserted in the database.
I'm attaching the zipped file in question. Perhaps you could have a look.
In this case I have 5 image upload fields on an update page. You can insert the image OK but if you do a blank update it deletes the existing file.
I've been researching this for over a day now and so I feel I've wasted enough time trying to solve this so could you help please.
Cologne
Do you have the right trigger: "if image uplad successful"
this should work
Originally Said By: Cologne
this should work
Thanks for the suggestion but that didn't work I'm afraid. I have the trigger set to the form submit button being pressed. This uploads a new file and enters the file name in the database but if pressed without uploading a new file, it does not retain the info in the database (it deletes it). All this despite following the guide for this very thing found here http://assets.webassist.com/how-tos/dfp_da_insert_update_ht.pdf
To trouble shoot this, change line 203:
$WA_redirectURL = "users_Images.php";
$WA_redirectURL = "";
so that no redirect happens after updating the database.
Then add the following code for turning on error reporting at line 1:
error_reporting
(E_ALL);
next add this code after the <body> tag.
Post back any PHP errors that may display and the results of the DFP debug info after testing.
Solved
Hi jason,
Many thanks for looking into this but because of the time delay between the UK and the west coast of the US I have had all day to really have a go at this. It turns out to be a simple "error" on my part. Not really an error but "it wasn't in the manual" so I didn't do it.
The problem stemmed from the fact of uploading two images (the 2nd being a thumbnail). In the DFP behaviour I inserted the default hiddenfile valuefor the main image but left this blank for the thumbnail. As this data was not being inserted into the database but merely uploaded to another folder, It didn't seem logical to me to have to give the thumbnail a default value.
Well the answer is that you do. By just placing the same default value in for the thumbnail as for the main image it stopped the database from being deleted.
Problem solved.
excellent, glad to hear you have it working.
CraigRBeta Tester
Hey John, I am also in the UK, and pretty new to DFP, (previously used D. Powers hand built solution).
Anyway to keep it short, I have a ticket open on this same problem.
If I get no joy within the next few days, can I drop you a message ?
Regards
Originally Said By: CraigR
Regards
Of course you can. We can only try :)
