Help with querying a mySQL/PHP database using a List/menu pulldown.
Thread began 11/16/2009 11:19 am by ResB | Last modified 11/17/2009 9:20 am by Jason Byrnes | 1957 views | 3 replies |
ResB
Can someone point me in the right direction on how to do this.
I have a couple of Tables, one with Car manufacturers, the other with car models.
I want to be able to use a pull down menu to select the manufacturer and once selected, I'd like a query to be sent to the database pulling only data which matches the manufacturer I've selected. If that makes sense.
The pull down is already in a state where it is populated with the manufacturers. Each manufacturer has a unique key i.e.
Alfa Romeo = 1
Audi = 2
etc
Any online resource would be very helpful.
Thanks in anticipation.
Rich
This can be done using the Dynamic DropDowns Extension:
See the Dynaic Dropdowns getting started guide in the Getting Started section of the Dynamic Dropdowns support page for information :
dynamic-dropdowns/
ResB
Great but will it work for my example, albeit not very clear.
The first menu will be populated with the Manufacturers. When I select a manufacturer I don't want to populate another menu or list box, I want to used the selected manufacturer to query a separate table and display the relevant rows which match the selected id from the manufacturer.
Thanks again.
Yes, that is what Dynamic Dropdowns is designed to do.
