I'm getting the " UspsCom:oAuth" Failure on the shipping page.
Thread begun 11/16/2009 10:13 am by rmcadams351257 | Last modified 11/19/2009 6:02 pm by Eric Mittman | 6893 views | 7 replies |
rmcadams351257
I hope you can help me with the powerstore2 program.
After reading through the posts, dealing with this issue.
I know I'm using the correct user name they gave me and I'm using the production server address they gave me."http://production.shippingapis.com/shippingapi.dll".
When USPS sent me my user name they also sent me a password. I did not use the password however as there was no place to put it in the code on the globals page.
When I run this code on the shipping_failure.php page
if(!session_id()) session_start();
echo("Paypal Full Response :<br />");
echo("<code>".isset($_SESSION["PP_DirectPayment"])?$_SESSION["PP_DirectPayment"]:""."</code><br /><br />");
echo("USPS Full Response :<br />");
echo("<code>".isset($_SESSION["WA_Store_Cart_USPS_FullResponse"])?$_SESSION["WA_Store_Cart_USPS_FullResponse"]:""."</code><br /><br />");
I get the response:
80040b1a Authorization failure. You are not authorized to connect to this server. UspsCom
When I talked with USPS they told me my account is active and good on that end.
I'm at a loss, to what I'm doing wrong.
If you need me to send you the files Golbals,Shipping_failure...Ect. let me know and I will be happy to put them in a zip file, just let me know the ones you need.
Thanks for all your help in this matter
Ron
I think you should run another test of this but put in the full request on the page as well as the full response from the bindings. This way we can confirm the values that are being sent to USPS.
Also, not sure if it will make a difference but sometimes USPS wants you to do some tests first with their testing server before they allow the production. This should not be the case since we are working with the v3 api which does not allow for testing. Just something else that can be looked into with USPS.
rmcadams351257
need the full response from the bindings
Hi: Eric
I'm kind of new to php and I'm not sure how to "put in the full request on the page as well as the full response from the bindings"
I think I got the full request on the shipping_failure page ok, But I'm not sure how to do the full responce from the bindings. Does it go on the shipping_failure page also and what is the code? Can you post the code for me & let me know what page they should be on?
Let me know an I'll run the code again and get the full responce.
Again Eric thanks for your help.
Ron
thedvs1.com
mc3products.com
Oh, sorry about that, I assumed that you were already working with these bindings. These values are located in the bindings tab under the usps result. Here they are for reference:
full request
<?php echo $_SESSION["WA_Store_Cart_USPS_FullRequest"]; ?>
full reponse
<?php echo $_SESSION["WA_Store_Cart_USPS_FullResponse"]; ?>
You would want to put these on the shipping failure page and any other page after the confirm page that you would like to see these values.
rmcadams351257
I added the request & responce codes
Hi: Eric
I added that code to the shipping_failure page.
Here is an update. I talked with USPS and they had me open another account,Then they moved it to the production server.
I went to the web page, that still had the code I had put in. I had changed the globels to reflect the new User ID for USPS & got this
Shipping Quote Failed
We're sorry
Rate_Respond.;SOLServerRates.RateV3_Respond - Invalid XML Element content is invalid according to the DTD/Schema. Expecting: FirstClassMailType, ZipOrigination. line= 0 pos= 1237
That was new. So then I added the request & responce codes as you ask and I got this.
(I think I did it right)..:)
API=RateV3&XML=FIRST CLASSFIRST CLASS9130630REGULAR -2147219085Rate_Respond.;SOLServerRates.RateV3_RespondInvalid XML Element content is invalid according to the DTD/Schema. Expecting: FirstClassMailType, ZipOrigination. line= 0 pos= 12371000440
Did that help?
Thanks again Eric
Ron
To tell you the truth this error is not one that I have seen before, nor any like it. It seems to be saying that the xml is malformed and not accepted by the api.
When you talked to USPS what type of account did they open for you? Did you get a new production server URL to post to? If so what is that new URL? If you have not been given the production URL from USPS you should try to login and obtain the one that they are listing for you and post back with this value.
rmcadams351257
USPS sent me this email
Hi; Eric
When I signed up USPS sent me this email.
Congratulations on completing your testing using the U.S. Postal
Service's Web Tools Application Program Interfaces (APIs). Your
profile has been updated to allow you access to the Production Servers.
The URLs you will use for the Production Servers are:
ShippingAPI.dll
ShippingAPI.dll
So I used ShippingAPI.dll.
I did notice the API part was in caps, I tryed both ways ShippingAPI.dll & Shippingapi.dll
and got same responce.
This is what my USPS globels looks like.
// USPS Shipping Settings
$WAGLOBAL_USPS_User = "***********"; // get this when you sign up for API access
$WAGLOBAL_USPS_Server = "http://production.shippingapis.com/ShippingAPI.dll"; // change this to the live server when you go live
$WAGLOBAL_USPS_ShipType = "FIRST CLASS"; //Enter the appropriate value for domestic shipping, based on the USPS Shipping key at the bottom of this page.
$WAGLOBAL_USPS_IntShipType = "Economy (Surface) Parcel Post"; //Enter the appropriate value for shipping to international customers, based on the USPS
I'm at a loss....
Thanks Eric
Ron
I have opened a ticket for you so that we can exchange some more info. Please login to the site and visit your support history to update the ticket.
