Master/Detail Order/Line Items
Thread begun 4/25/2009 10:35 am by glmcps295424 | Last modified 4/27/2009 9:00 am by Ray Borduin | 2267 views | 1 replies |
glmcps295424
Using Data Assist I've added the results page of the line items file to the detail page of the order file. filtering works fine when detail page is viewed . However, when adding a line item there is a problem when returning to the orders detail page. Neither the order detail or the line items table shows.
Could someone suggest how to accomplish this . I expect it's an issue with the filtering but am stumped.
Thanks for your time,
Gregg
It is probably using the url parameter to filter the child recordset, where there is special code that uses a session variable after an insert I believe. You would probably have to identify that code and make sure it is replicated for the second recordset parameter.
