Creating the Dynamic Array / text or data
Thread begun 11/15/2009 12:33 pm by brunodarwin371999 | Last modified 1/08/2011 7:15 pm by MR.gabriel | 10475 views | 9 replies |
brunodarwin371999
In my data base, let's say that :
- the Parent is "articles"
- the Child list "spares" is the corresponding spare parts list (screw, O-ring, nut) for each above "article"
My question referes to the pdf "Getting Started with Dyamic Dropdowns", page 7 of 10 , point 7
> We have to "choose the text or data for the child table".
Question : What can be the column that contains text or data if my Child table is made with the following columns : idspares (PK) ,screw, O-ring, nut, idarticle (FK) ?
Thank you in advance.
We need a little more information.
How do Articles relate to spares?
How is the database constructed?
brunodarwin371999
here is the requested information
Hi Jason,
You will find attached a .jpg file to show you visualy the structure of the dataBase.
Hereunder, here is the SQL file which corresponds to it :
SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0;
SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0;
SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='TRADITIONAL';
CREATE SCHEMA IF NOT EXISTS `wa_sample` DEFAULT CHARACTER SET utf8 COLLATE utf8_general_ci ;
USE `wa_sample`;
-- Table `wa_sample`.`articles`
CREATE TABLE IF NOT EXISTS `wa_sample`.`articles` (
`idarticles` INT NOT NULL AUTO_INCREMENT ,
`article` VARCHAR(45) NOT NULL ,
PRIMARY KEY (`idarticles`) )
ENGINE = InnoDB;
-- Table `wa_sample`.`spares`
CREATE TABLE IF NOT EXISTS `wa_sample`.`spares` (
`idspares` INT NOT NULL AUTO_INCREMENT ,
`screw` VARCHAR(45) NULL ,
`o-ring` VARCHAR(45) NULL ,
`nut` VARCHAR(45) NULL ,
`articles_idarticles` INT NOT NULL ,
PRIMARY KEY (`idspares`) ,
INDEX `fk_spares_articles` (`articles_idarticles` ASC) ,
CONSTRAINT `fk_spares_articles`
FOREIGN KEY (`articles_idarticles` )
REFERENCES `wa_sample`.`articles` (`idarticles` )
ON DELETE NO ACTION
ON UPDATE NO ACTION)
ENGINE = InnoDB;
SET SQL_MODE=@OLD_SQL_MODE;
SET FOREIGN_KEY_CHECKS=@OLD_FOREIGN_KEY_CHECKS;
SET UNIQUE_CHECKS=@OLD_UNIQUE_CHECKS;
I'm not sure i understand this database structure.
Can you sand a screen shoot showing the data in these two tables.
brunodarwin371999
You will find attached a drawing helping you to understand this database struture.
to sum up, article#1 generates 3 spares :
- Screw#1
- o-ring#1
- nut#1
article#n generates 3 spares :
- Screw#n
- o-ring#n
- nut#n
I hope this helps.
This is basiclythe same screen shot as in your previous post.
Please provide a screen shoot showing the data in the 2 tables, not the structure so I can get a better understanding.
brunodarwin371999
Please find attached the two tables parent (articles) and child (spares) data.
The two pictures belong to a phpmyadmin screen capture...
this Database structure will not work with dynamic drop downs.
your database structure should be more like:
articles:
articleId - primary Key
articleName - text
sparetypes:
spareTypeID - primary Key
sapreTypeName - text
articlespares:
articlesparesID - primary key
articlesparesSpareTypeID - foregin key to sparetypes.spareTypeID
articlesparesarticleId - foregin key to articles.articleId
MR.gabriel
Creating Dynamic Array Proplem GSG...
My issue is similar in that I'm going throught the GSG for Dynamic Dropdown and on page 7 at point "5. From the Parent ID field menu, choose the ParentID column."
Once I've chosen the "Child table" (from point #4) It doesn't give me the option to select the Parent ID for the "Parent ID field:". Only the ChildID (that was established by my record sed) shows.
I've checked my DB (phpMyAdmin) and the foreign key was created and the Parent and Child tables are related. I am stuck.
Help Please!
-- Table structure for table `Child`
CREATE TABLE `Child` (
`ChildID` int(20) NOT NULL auto_increment,
`ChildText` text NOT NULL,
PRIMARY KEY (`ChildID`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8 AUTO_INCREMENT=1 ;
-- Dumping data for table `Child`
-- Constraints for dumped tables
-- Constraints for table `Child`
ALTER TABLE `Child`
ADD CONSTRAINT `Child_ibfk_1` FOREIGN KEY (`ChildID`) REFERENCES `Parent` (`ParentID`) ON DELETE CASCADE ON UPDATE CASCADE;
-- Table structure for table `Parent`
CREATE TABLE `Parent` (
`ParentID` int(20) NOT NULL auto_increment,
`ParentText` text NOT NULL,
PRIMARY KEY (`ParentID`)
-- Dumping data for table `Parent`
MR.gabriel
Fixed, Database was the problem
My database "Chlid" was missing the Parent ID as a column. Once I did that then indexed it Dynamic Array was able to detect it.
