How to view the original example designs for FB?
Thread begun 11/13/2009 6:56 pm by Stevebo | Last modified 11/19/2009 10:07 am by Anna Robinson | 2855 views | 4 replies |
Stevebo
Somewhere along the line (probably when I first started using FB), I have overwritten the form samples that came with Form Builder. How can I restore those originals so that I can use them rather than seeing the ones I overwrote by accident?
steve
These form presets are not available as a separate download so you will need to uninstall Form Builder then re-install it in order to get the original presets back. You can back up any custom ones or ones that you would like to keep by exporting them from the preset manager first.
Stevebo
Hmmm. I've uninstalled FB and reinstalled the latest version and I still see the modified original forms from FB. Could there be something else I'm doing wrong?
Sorry about that, I thought the uninstall and reinstall would do it. You can probably get it done this way but would need to remove the preset from the preset manager first.
I'm including a zip of the presets for your convenience, you should be able to remove what you have and import these to get a fresh start.
Anna Robinson
We are now offering ALL of the CSS Form Builder default presets (design, group and content) in the Download Center. Log in and visit the Download Center. Click on CSS Form Builder and then click on the presets section to download the zip.
These can be imported into CSS Form Builder, using the Preset Manager, should you ever lose your default presets.
