Trouble adding item from Recordset...
Thread begun 11/12/2009 7:45 am by fdotmedia | Last modified 11/12/2009 4:12 pm by Jason Byrnes | 2095 views | 3 replies |
fdotmedia
I have got the dynamic portion of the script working so it adds the product. But when I set up the scipt to redirect on add it doesn't go anywhere, so you have to click on the "view cart" button to actually view the cart...
any suggestions?
see code below...
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
$eCart1->GetContent();
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "shopping-cart.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_LabTest) && $totalRows_LabTest > 0) {
$row_LabTest = WAEC_findRecordMySQL($LabTest, "LID", $ATC_itemID);
if ($row_LabTest) {
$ATC_itemName = "".$row_LabTest['LabTitle'] ."";// column binding
$ATC_itemDescription = "";// column binding
$ATC_itemWeight = floatval("".$row_LabTest['LabWeight'] ."");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_LabTest['LabPrice'] ."");// column binding
mysql_data_seek($LabTest, 0);
$row_LabTest = mysql_fetch_assoc($LabTest);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
There may be a PHP error occurring on the page causing the redirect to faile.
Add the following code at line 1:
error_reporting
(E_ALL);
to turn error reporting on.
please post back the error that is occurring, also if you could add the php page to a zip archive and attach it to your replay so I could see the entire code on the page, that would help me see what is going wrong.
fdotmedia
I don't get an error... I'd attach that as well...
Please let me know when you have a second...
Ted
Add the following code just before the doctype tag:
// WA eCart Redirect
if ($eCart1->redirStr != "")     {
header("Location: ".$eCart1->redirStr);
