Form
Thread begun 11/12/2009 5:59 am by A Sound Design | Last modified 11/13/2009 9:11 am by Jason Byrnes | 4400 views | 6 replies |
A Sound Design
Form
I have designed a form that works well but does not position correctly on the page. Rather than displaying at the top of the page it sits at the bottom with a huge gap. Please see the attachment.
The site is not yet online so I can't give a URL yet. The site was designed using the CSS Sculptor extension. I am using version 1.01 of the Form Builder extension.
neilo
Hi Jeremy,
Without seeing a working example of the page and being to follow through to the stylesheet, it will be difficult to pin-point the exact css problem. (Hopefully someone will disagree, and provide a solution).
What I would suggest is saving your page to yourpage_bak.php, then cutting (just) the formbuilder code from yourpage.php.
Then check that the pre-existing divs are properly styled to accept full-width content without displacing itself. It may be that you need to adjust the div styles' float and clear, or it may be that you need to reduce the width of your form. Or it may be that the exact placement of the form is the problem.
Perhaps you could zip your pages and stylesheet and upload it here so that someone can have a look?
Most likely, the width of the form exceeds the width of the main content area.
As neilo said in his post, without being able to see the problem in a web browser it is impossible to say exactly what css needs to be changed. I would start by decreasing the width of the form though.
A Sound Design
Ok. I've put it online in a test area at contact.php
in the screen.css file, add overflow: hidden; to the #outerWrapper #contentWrapper #content selector:
#outerWrapper #contentWrapper #content {
margin: 0 0 0 176px; /* Sets the margin properties for an element using shorthand notation (top, right, bottom, left) */
padding: 10px 10px 10px 10px; /* Sets the padding properties for an element using shorthand notation (top, right, bottom, left) */
overflow: hidden;
A Sound Design
Thanks Jason. That works. What exactly does it do?
The only problem with it is that now when I try to re-edit the form I cannot do it unless I go to Code View. If I take out the overflow: hidden; code I can re-edit the form using Form Builder. Strange. Ok, so I can comment it out but and un-comment it when finished but it's a bit of a pain. Actually, it affects all the code on the page (see attached screenshot).
It forces the form to the width of the content div.
The problem is that the form is wider than the content div. So the it is being pushed down the page to a place where there is enough room to display it.
By adding the overflow: hidden property it tells the browser to just not show the part of the form that overflows the boundary of the content div rather than push things down the page.
You either need to include the overflow: hidden property, or change the width of the form so it will fit within the content div.
