no Email while using PEAR
all of a sudden, I can't send E-Mails while using PEAR. I have no idea what my problem is. I updatted to the newes Universal Email.
-> I don't receive any Email
Can you send a copy of your page so I can examine the code.
$MailAttachments = "";
$MailBCC = "";
$MailCC = "";
$MailTo = "";
$MailBodyFormat = "";
$MailBody = "";
$MailImportance = "";
$MailFrom = "xx|WA|xx";
$MailSubject = "Check 01";
$_SERVER["QUERY_STRING"] = "";
//Global Variables
$WA_MailObject = WAUE_Definition("/home/web6/PEAR/","smtp.xx.de","25","xx","xx","true","","","","ISO-8859-1");
if ($RecipientEmail) {
$WA_MailObject = WAUE_AddRecipient($WA_MailObject,$RecipientEmail);
else {
//To Entries
//Attachment Entries
//BCC Entries
//CC Entries
//Body Format
$WA_MailObject = WAUE_BodyFormat($WA_MailObject,0);
//Set Importance
$WA_MailObject = WAUE_SetImportance($WA_MailObject,"3");
//Start Mail Body
del body for forum
//End Mail Body
$WA_MailObject = WAUE_SendMail($WA_MailObject,$MailAttachments,$MailBCC,$MailCC,$MailTo,$MailImportance,$MailFrom,$MailSubject,$MailBody);
$WA_MailObject = null;
do you need the WAUE_*.php , too?
THANKS !!!!
I checked the logfiles, no conection to the smtp server
I need the full php file you have applied the universal email server behavior to.
Please add that file to a zip archive and send it with your reply.
<?php require_once("../WA_Universal_Email/PEAR_Mail_using_SMTP_PHP.php"); ?>
<?php require_once("../WA_Universal_Email/MailFormatting_PHP.php"); ?>
if (("" == "")) {
//WA Universal Email object="PEAR Mail using SMTP"
//Send Loop Once Per Entry
$RecipientEmail = "xx@xx.com";include("../WA_Universal_Email/WAUE_*.php");
//Send Mail All Entries
if (""!="") {
header("Location: ");
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Unbenanntes Dokument</title>
</head>
<body>
</body>
</html>
and the wa.zip
It looks like that should work.
Is there a php error occurring?
Add the following at line 1:
error_reporting(E_ALL);
this will show any errors if there are any.
Perhaps try leaving the SMTP server blank?
where do you want the PHP Code? (what php File?)
I have to work with the SMTP Server :(
At line 1 of the page you have applied Universal Email to.
<?php require_once("WA_Universal_Email/PEAR_Mail_using_SMTP_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if (("" == "")) {
$RecipientEmail = "xx@xx.com";include("WA_Universal_Email/WAUE_xx_1.php");
if (""!="") {
<head>
</head>
<body>
</body>
</html>
so, no errors what's so ever !! :( - And no Emails :(
Have you tried leaving the SMTP server blank?
Are you entering a value for the From Display name? If so try leaving that blank as well.
