eCart, PowerStore 2, eWay, Australia ... Error
Thread begun 11/11/2009 6:22 pm by B Tonkin | Last modified 11/30/2009 6:07 pm by Eric Mittman | 8013 views | 23 replies |
B Tonkin
Having a bit of an issue with a Powerstore 2 setup, using eWay (Australia) as the Payment Gateway.
I've used the "Changing Payment Gateway" support guide (ps_change_pmtgateway_ecart.pdf) to change over to eWay, following the instructions carefully. The whole store seems to be working fine but in a test run I can't get past the Confirm page.
The error message that comes up is ...
Notice: Use of undefined constant tStat - assumed 'tStat' in /clientdata/n5200-2-dynamic/b/u/buywineonline.com.au/www/WA_eCart/Adv_CO_Scripts/eWAY_XML_PHP.php on line 113
Notice: Use of undefined constant tErr - assumed 'tErr' in /clientdata/n5200-2-dynamic/b/u/buywineonline.com.au/www/WA_eCart/Adv_CO_Scripts/eWAY_XML_PHP.php on line 114
Warning: Cannot modify header information - headers already sent by (output started at /clientdata/n5200-2-dynamic/b/u/buywineonline.com.au/www/WA_eCart/Adv_CO_Scripts/eWAY_XML_PHP.php:113) in /clientdata/n5200-2-dynamic/b/u/buywineonline.com.au/www/confirm.php on line 242
... lines 109 to 155 are as follows ...
$tStat = ((isset($valArr[strtoupper("ewayTrxnStatus")]))?$valArr[strtoupper("ewayTrxnStatus")]:"");
$tErr = ((isset($valArr[strtoupper("ewayTrxnError")]))?$valArr[strtoupper("ewayTrxnError")]:"");
if ($tStat == "False") {
$retVal->isError = true;
$retVal->errorCode = tStat;
$retVal->errorMessage = tErr;
... lines 241 to 244 are ...
else if ("checkout_failure.php" != "") {
header("Location: ". "checkout_failure.php");
exit();
... our eWay account seems to be valid. Nothing suggests otherwise.
Any thoughts?
In this code you should try updating lines 113 and 114 to be like this:
$retVal->errorCode = $tStat;
$retVal->errorMessage = $tErr;
I think this should clear up all these errors you are getting. Please make this update and make sure to upload the file and test it again. After you test please post back with the results, if this fixes these errors I will ensure that a bug is logged for this.
B Tonkin
Solved one issue, created another
Yeah, that solved that problem, Eric. Only problem is that it ended up on the failure page after submitting my CC details ...
We're sorry
Your transaction could not be completed. Either your credit card information or billing address has problems and cannot be processed
Please return to checkout and try again.
... pretty sure neither had issues. Can I get the system to tell me more information than the above?
B Tonkin
Ignore that
Sorted it out. Didn't realise I was on their testing gateway.
Good catch. So it sounds like you are getting successful test transactions now rite?
B Tonkin
Success!
Indeed. Working fine now.
Glad to hear, let us know if you have any other troubles with any part of this.
B Tonkin
Sorry Eric, Me Again
Hey Eric,
I indicated that the checkout process was working, but it's not really. Goes through the eWay payment gateway but ends up back at the site staring at an empty cart as opposed to the checkout_success.php page. Seems to briefly load it but lines 9 to 13 on that page redirects user to cart.php if a Session (OrderID) isn't set, so I'm, assuming that's where my problem lies.
Any suggestions on what I need to do? I assume it doesn't need to pass the Session through to eWay if it's a local transaction?
What do I need to do?
- Bruce
The problem may have to do with how the session is working for you. When the user is on the site before they checkout take a look at the URL and record it. Then take a look at the page that you have specified for the return, you will need to ensure that the domains match up correctly.
For example if your URL on the checkout page is www.domain.com and the page you have specified as the return is set to just domain.com then the session will be lost also look for http vs https, this can have a similar result. If this does not work out for you let me know and we can try a different approach.
B Tonkin
The checkout process (with URLs) goes like this ...
1) cart.php
2) checkout.php (form action there is "confirm.php")
3) confirm.php
4) cart_success.php (redirection here)
5) cart.php (empty)
