ORDER BY DESCENDING command in Record Set Query
Thread begun 11/11/2009 3:29 pm by ijk76319396 | Last modified 11/11/2009 4:30 pm by Justin Nemeth | 2467 views | 1 replies |
ijk76319396
I would like to display images uploaded in a database in order by DESCENDING but with the basic recordset feature on Dreamweaver it will automatically display the last uploaded file. How can I command it to display the second to last file, third to last ect. I have been trying commands such as ORDER BY page_1 DESC then adding (-1) (minus-1) etc. but none of them have worked yet. Is there a simple line I can add directly after- ORDER BY page_1 DESC to achieve this?
Justin Nemeth
Assuming you are using MySQL, using LIMIT will do what you want. The syntax is LIMIT [offset], [row count]. The offset starts counting at 0, so row 1 = 0, row 2 = 1, and so on.
So an example query that started at the 2nd row and returned 1 result would have:
SELECT * FROM table ORDER BY page_1 DESC LIMIT 1, 1
-justin
