Change size of Captcha text input field?
Thread begun 11/11/2009 1:59 pm by mywebassist220499 | Last modified 11/12/2009 1:55 pm by mywebassist220499 | 3753 views | 5 replies |
mywebassist220499
How can I change the size of the text input field for the captcha feature in CSS Form Builder while in design mode?
Right now it defualts to: class="formTextfield_Large" and I can't seem to find anywhere in the interface to change this. If I change it in the source on the page, it reverts back if I edit the design through the CSS Form Builder interface.
Dani Chankhour
I did some testing and it seems that Captcha always have a standard size that can't be changed.
I will log a bug in our bug base in regard to this issue.
The only other work around would be to change the large text filed width be click the Edit next to Design and then selecting form elements and text fields.
Dani Chankhour
I'm sorry i might have misunderstood the questions. If you wanted to change the input field then you can change that by clicking the Edit button next to Design in the quick insert and then select form elements from the first drop down list and then selecting text. Under size select large and change the width.
mywebassist220499
Originally Said By: Dani Chankhour
No, you understood correctly in your first reply: You cannot change the text "Size" element for the Captcha's text input field to a different size like "Small". It is set as "Large" which seems an odd choice to me for this type of use.
Dani Chankhour
OK, I have logged the bug in our bug base, and it should be fixed in our next dot release.
mywebassist220499
Thanks Dani
