Irite was better??
Hello
I purchased the new HTML editor but it won't work. There is no update or insert into the database and there is an java error. The upate and insert works fine without the HTML editor.
I Deleted the old irite file's.
Why?
Hello
Why?
Please try deleting your Cache file. This link have the steps:
146/
Ok the java message is gone, also the extentions.
Now the update won't work if i do an update notting happens the old input is gone and the update is empty.
**** happens.
Are you using DataAssist Server Behavior to insert and update?
If so, please reenter the server behavior and make sure to select the html editor instance again, as the name might have changed during the update. I would also recommend to delete the html editor instance and add replace it with a new one if you are still seeing the issue.
